10004.1
10004.1
    CONTA-CLIP
    插件,P=5mm
    PCB TERMINAL
10004.1 数据手册
Data sheet 10004.1 PK 100/5/5,00-V GN PCB terminal, Wire protection, No. of poles: 5, Width: 25.7 mm, Colour: Green Business data Article number 10004.1 Article name PK 100/5/5,00-V GN GTIN (EAN) 4044211000073 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 5.7 g Weight per piece (including packaging) 6.43 g Unit of weight G Customs number 85369010 Country of origin TN Prio-Article 10004.1 Creation date 14.12.2023 19:20:35 Subject to technical changes 1 Data sheet 10004.1 PK 100/5/5,00-V GN Technical data Dimensions Length 9 mm Length of the pin 4.5 mm Width 25.7 mm Width left 3.2 mm Width right 2.5 mm Height 12.5 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 14.12.2023 19:20:35 Subject to technical changes 2 Data sheet 10004.1 PK 100/5/5,00-V GN Technical data Connection data Connection principle Wire protection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) No. of poles 5 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 7 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Wire protection Stainless steel Creation date 14.12.2023 19:20:35 Subject to technical changes 3 Data sheet 10004.1 PK 100/5/5,00-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 14.12.2023 19:20:35 Subject to technical changes 4 Data sheet 10004.1 PK 100/5/5,00-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 12 cUL wire cross-section stranded AWG, max. 22 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 12 UL wire cross-section stranded AWG, max. 22 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 14.12.2023 19:20:35 Subject to technical changes 5 Data sheet 10004.1 PK 100/5/5,00-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 19:20:35 Subject to technical changes 6 Data sheet 10004.1 PK 100/5/5,00-V GN Media Creation date 14.12.2023 19:20:35 Subject to technical changes 7 Data sheet 10004.1 PK 100/5/5,00-V GN Accessories Creation date 14.12.2023 19:20:35 Subject to technical changes 8
10004.1
- 物料型号: 10004.1 PK 100/5/5,00-V GN - 器件简介: 该产品为PCB端子,具有5个极数,宽度为25.7毫米,颜色为绿色,用于电缆保护。 - 引脚分配: 产品具有5个引脚,引脚间距为5毫米,连接针直径为1毫米。 - 参数特性: - 额定电压: 250V - 额定电流: 24A - 额定截面积: 2.5 mm² - 额定脉冲电压: 2kV - 污染等级: 3 - 工作温度范围: -30°C 至 105°C - 存储温度范围: -40°C 至 105°C - 绝缘电阻: 1×10^13欧姆×厘米 - 爬电电流电阻: CTI600 - 灼热丝可燃性指数(GWFI): GWFI850 - 灼热丝点燃温度(GWIT): GWIT 775°C - 连接循环次数: 5次 - 推荐波峰焊接温度: 265°C - 推荐波峰焊接时间: 3至4秒 - 功能详解: - 连接原理: 电缆保护 - PCB连接类型: 焊接连接 - 连接到电路板的类型: 连接接触 - PCB/线缆连接角度: 0/180°(水平) - 应用信息: 产品适用于电缆保护,具有特定的额定电压和电流,适用于多种线缆截面积。 - 封装信息: - 绝缘体材料: 聚酰胺6.6 - 阻燃等级: UL 94 V-0 - 螺丝: 钢制 - 电缆保护: 不锈钢
10004.1 价格&库存
很抱歉,暂时无法提供与“10004.1”相匹配的价格&库存,您可以联系我们找货
