10093.1
10093.1
    CONTA-CLIP
    插件,P=7.5mm
    接线端子 1x7P 7.5mm 直插 排数:单排 每排Pin数:7
10093.1 数据手册
Data sheet 10093.1 PK 114/7/7,50-V GN PCB terminal, Wire protection, No. of poles: 7, Width: 53.2 mm, Colour: Green Business data Article number 10093.1 Article name PK 114/7/7,50-V GN GTIN (EAN) 4044211002084 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 9.57 g Weight per piece (including packaging) 10.27 g Unit of weight G Customs number 85369010 Country of origin TN Prio-Article 10093.1 Creation date 14.12.2023 19:15:43 Subject to technical changes 1 Data sheet 10093.1 PK 114/7/7,50-V GN Technical data Dimensions Length 9 mm Length of the pin 2.5 mm Width 53.2 mm Width left 4.45 mm Width right 3.75 mm Height 12.5 mm Drill hole diameter 2 mm Diameter of connecting pin 1.2 mm Pitch 7.5 mm Ratings Rated voltage 500 V Rated current 32 A Rated cross-section 4 mm² Rated impulse voltage 3 kV Overvoltage category III Contamination degree 3 Creation date 14.12.2023 19:15:43 Subject to technical changes 2 Data sheet 10093.1 PK 114/7/7,50-V GN Technical data Connection data Connection principle Wire protection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) No. of poles 7 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 7 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Wire protection Stainless steel Creation date 14.12.2023 19:15:43 Subject to technical changes 3 Data sheet 10093.1 PK 114/7/7,50-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 14.12.2023 19:15:43 Subject to technical changes 4 Data sheet 10093.1 PK 114/7/7,50-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 20 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 12 cUL wire cross-section stranded AWG, max. 22 cUL torque 0.8000000119 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 20 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 12 UL wire cross-section stranded AWG, max. 22 UL torque 7398 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 14.12.2023 19:15:43 Subject to technical changes 5 Data sheet 10093.1 PK 114/7/7,50-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 500 V VDE rated current 32 A VDE rated current wire cross-section rigid, max. 32 A VDE rated current wire cross-section stranded, max. 32 A VDE rated impulse voltage 3 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 4 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 4 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 19:15:43 Subject to technical changes 6 Data sheet 10093.1 PK 114/7/7,50-V GN Media Creation date 14.12.2023 19:15:43 Subject to technical changes 7 Data sheet 10093.1 PK 114/7/7,50-V GN Accessories Creation date 14.12.2023 19:15:43 Subject to technical changes 8
10093.1
物料型号》:TI 公司的 LMR33630 《器件简介》:LMR33630 是一款同步降压型 DC/DC 转换器,适用于多种输入电压和输出电压。
引脚分配》:1(GND),2(SW),3(FB),4(EN),5(VIN),6(PG),7(VOUT),8(NC),9(NC),10(PAD)。
参数特性》:输入电压范围 4.5V 至 36V,输出电压范围 0.6V 至 16V,最大输出电流 3A。
功能详解》:具有软启动功能,可编程的软启动时间,可编程的输出电压,可编程的输出电流限制。
应用信息》:适用于多种应用场景,如电池供电设备、便携式电子设备等。
封装信息》:采用 10 引脚的 QFN 封装形式。
10093.1 价格&库存
很抱歉,暂时无法提供与“10093.1”相匹配的价格&库存,您可以联系我们找货
