1010.5
1010.5
    CONTA-CLIP
    FEED-THROUGH TERMINAL
1010.5 数据手册
Data sheet 1010.5 RK 1,5-4/15 BU Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 1010.5 Article name RK 1,5-4/15 BU GTIN (EAN) 4044211002381 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 5.4 g Weight per piece (including packaging) 5.64 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 1010.2 Product description Feed-through terminal Creation date 17.12.2023 15:43:37 Subject to technical changes 1 Data sheet 1010.5 RK 1,5-4/15 BU Technical data Dimensions Length 27 mm Width 6 mm Height TS 15/5.5 34.5 mm Ratings Rated voltage 500 V Rated current 32 A Rated cross-section 4 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.02 W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 10 Stripping length 9 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 17.12.2023 15:43:37 Subject to technical changes 2 Data sheet 1010.5 RK 1,5-4/15 BU Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type TS 15 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 1 End plate required Number of test pick-off options 2 Environmental Product Compliance REACH Conform Yes REACH Candidate Substance Note No Creation date 17.12.2023 15:43:37 Subject to technical changes 3 Data sheet 1010.5 RK 1,5-4/15 BU Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 40 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 10 CSA stripping length 9 mm CSA torque, max. 1 Nm CSA torque, min. 0.5 Nm CSA File Number 042110_0_000 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 500 V KEMA rated current 32 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² Creation date 17.12.2023 15:43:37 Subject to technical changes 4 Data sheet 1010.5 RK 1,5-4/15 BU Approvals UL Recognized UL approval UL 1059 UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 30 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 10 UL torque 7 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL File Number E95701 UL Recognized 1 German Lloyd approval DNV GL Certificate number TAE000014T DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 4 mm² DNV GL rated current 34 A DNV GL rated voltage 500 V DNV GL test standard IEC 60947-7-1:2002 Creation date 17.12.2023 15:43:37 Subject to technical changes 5 Data sheet 1010.5 RK 1,5-4/15 BU Media Creation date 17.12.2023 15:43:37 Subject to technical changes 6 Data sheet 1010.5 RK 1,5-4/15 BU Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2738.2 AP 1,5-4 BG 4044211054748 50 End stop End stop, Mounting type: Mounting rail TS 15/5.5, Width: 7.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2074.2 ES 15 BG 4044211048822 50 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Insulation plate Insulation plate, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2566.2 TRS 3 BG 4044211053567 100 ST Partition plate Creation date 17.12.2023 15:43:37 Subject to technical changes 7 Data sheet 1010.5 RK 1,5-4/15 BU Partition plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2071.2 TW 1,5-4 BG 4044211048792 50 Creation date 17.12.2023 15:43:37 Subject to technical changes 8
1010.5 价格&库存
很抱歉,暂时无法提供与“1010.5”相匹配的价格&库存,您可以联系我们找货
