1015.7
1015.7
    CONTA-CLIP
    FEED-THROUGH TERMINAL
1015.7 数据手册
Data sheet 1015.7 RK 1,5-4 WH Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated crosssection: 4 mm², Width: 6 mm, Colour: White RAL: 9010 Business data Article number 1015.7 Article name RK 1,5-4 WH GTIN (EAN) 4044211003562 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 6.8 g Weight per piece (including packaging) 7.29 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 1015.2 Product description Feed-through terminal Creation date 17.12.2023 15:49:19 Subject to technical changes 1 Data sheet 1015.7 RK 1,5-4 WH Technical data Dimensions Length 45 mm Width 6 mm Height TS 35/7.5 43.5 mm Height TS 32 48 mm Ratings Rated voltage 500 V Rated current 32 A Rated cross-section 4 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.02 W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 10 Stripping length 9 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 17.12.2023 15:49:19 Subject to technical changes 2 Data sheet 1015.7 RK 1,5-4 WH Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7.5 and TS 32 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 1 End plate required Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 15:49:19 No Subject to technical changes 3 Data sheet 1015.7 RK 1,5-4 WH Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 40 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 10 CSA stripping length 9 mm CSA torque, max. 1 Nm CSA torque, min. 0.5 Nm CSA File Number 042110_0_000 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 500 V KEMA rated current 32 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² Creation date 17.12.2023 15:49:19 Subject to technical changes 4 Data sheet 1015.7 RK 1,5-4 WH Approvals UL Recognized UL approval UL 1059 UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 30 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 10 UL torque 7 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL File Number E95701 UL Recognized 1 German Lloyd approval DNV GL Certificate number TAE000014T DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 4 mm² DNV GL rated current 34 A DNV GL rated voltage 500 V DNV GL test standard IEC 60947-7-1:2002 Creation date 17.12.2023 15:49:19 Subject to technical changes 5 Data sheet 1015.7 RK 1,5-4 WH Media Creation date 17.12.2023 15:49:19 Subject to technical changes 6 Data sheet 1015.7 RK 1,5-4 WH Accessories Cover Cover, Length: 24 mm, Width: 24 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2494.0 AD 4/24/B/E YE 4044211052959 50 ST Cover, Length: 24 mm, Width: 24 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2011.0 AD 4/24/B YE 4044211048143 50 ST Cover, Length: 24 mm, Width: 20 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2493.0 AD 4/24/B/E YE 4044211052942 50 ST Cover, Length: 24 mm, Width: 20 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2079.0 AD 4/24/B YE 4044211048877 50 ST End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2738.2 AP 1,5-4 BG 4044211054748 50 End stop Creation date 17.12.2023 15:49:19 Subject to technical changes 7 Data sheet 1015.7 RK 1,5-4 WH End stop, Mounting type: Mounting rail TS 35/7.5, Width: 7.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2005.2 ES 35 BG 4044211048082 50 Cross-connector Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 10.5 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2087.0 Q2 4044211048952 50 ST Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 22.7 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2089.0 Q4 4044211048976 20 ST Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 59.3 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2090.0 Q 10 4044211048983 10 ST Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 16.6 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2088.0 Q3 4044211048969 50 ST Insulation plate Creation date 17.12.2023 15:49:19 Subject to technical changes 8 Data sheet 1015.7 RK 1,5-4 WH Insulation plate, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2566.2 TRS 3 BG 4044211053567 100 ST Partition plate Partition plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2071.2 TW 1,5-4 BG 4044211048792 50 Creation date 17.12.2023 15:49:19 Subject to technical changes 9
1015.7 价格&库存
很抱歉,暂时无法提供与“1015.7”相匹配的价格&库存,您可以联系我们找货
