Data sheet
1015.9 RK 1,5-4 RD
Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated crosssection: 4 mm², Width: 6 mm, Colour: Red
Business data
Article number
1015.9
Article name
RK 1,5-4 RD
GTIN (EAN)
4044211003623
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
6.8 g
Weight per piece (including packaging)
7.29 g
Unit of weight
G
Customs number
85369010
Country of origin
CZ
Prio-Article
1015.2
Product description
Creation date 17.12.2023 15:52:34
Subject to technical changes
1
Data sheet
1015.9 RK 1,5-4 RD
Technical data
Dimensions
Length
45 mm
Width
6 mm
Height TS 35/7.5
43.5 mm
Height TS 32
48 mm
Ratings
Rated voltage
500 V
Rated current
32 A
Rated cross-section
4 mm²
Rated impulse voltage
6 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
1.02 W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
2
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
4 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
10
Stripping length
9 mm
Screw head
Slotted
Screw threading
M3
Tightening torque, min.
0.5 Nm
Tightening torque, max.
1 Nm
2
Data sheet
1015.9 RK 1,5-4 RD
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Gauge plug acc. to EN 60 947-1
A4
Number of cross-connection channels
1
End plate required
Environmental Product Compliance
REACH Candidate Substance Note
No
3
Data sheet
1015.9 RK 1,5-4 RD
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
300 V
CSA Usegroup C: rated current
40 A
CSA wire cross-section AWG, min.
22
CSA wire cross-section AWG, max.
10
CSA stripping length
9 mm
CSA torque, max.
1 Nm
CSA torque, min.
0.5 Nm
CSA File Number
042110_0_000
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
500 V
KEMA rated current
32 A
KEMA rated impulse voltage
6 kV
KEMA wire cross-section single core (rigid), min.
0.2 mm²
KEMA wire cross-section single-core (rigid), max.
4 mm²
KEMA wire cross-section stranded, min.
0.2 mm²
KEMA wire cross-section stranded, max.
4 mm²
4
Data sheet
1015.9 RK 1,5-4 RD
Approvals
UL Recognized
UL approval
UL 1059
UL Usegroup C: rated voltage
300 V
UL Usegroup C: rated current
30 A
UL wire cross-section single-core (rigid) AWG, min.
22
UL wire cross-section single-core (rigid) AWG, max.
10
UL wire cross-section stranded AWG, min.
22
UL wire cross-section stranded AWG, max.
10
UL torque
7 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL File Number
E95701
UL Recognized
1
German Lloyd approval
DNV GL Certificate number
TAE000014T
DNV GL Location Classes
Temperature: B, Humidity: B, Vibration: A
DNV GL approval granted
1
DNV GL rated cross-section
4 mm²
DNV GL rated current
34 A
DNV GL rated voltage
500 V
DNV GL test standard
IEC 60947-7-1:2002
5
Data sheet
1015.9 RK 1,5-4 RD
Media
6
Data sheet
1015.9 RK 1,5-4 RD
Accessories
Cover
Cover, Length: 24 mm, Width: 24 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2494.0
AD 4/24/B/E YE
4044211052959
50 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
2011.0
AD 4/24/B YE
4044211048143
50 ST
Cover, Length: 24 mm, Width: 20 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2493.0
AD 4/24/B/E YE
4044211052942
50 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
2079.0
AD 4/24/B YE
4044211048877
50 ST
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2738.2
AP 1,5-4 BG
4044211054748
50
End stop
7
Data sheet
1015.9 RK 1,5-4 RD
End stop, Mounting type: Mounting rail TS 35/7.5, Width: 7.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2005.2
ES 35 BG
4044211048082
50
Cross-connector
Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 10.5 mm,
Rated cross-section: 4 mm², Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2087.0
Q2
4044211048952
50 ST
Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 22.7 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2089.0
Q4
4044211048976
20 ST
Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 59.3 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2090.0
Q 10
4044211048983
10 ST
Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 16.6 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2088.0
Q3
4044211048969
50 ST
Insulation plate
8
Data sheet
1015.9 RK 1,5-4 RD
Insulation plate, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2566.2
TRS 3 BG
4044211053567
100 ST
Partition plate
Partition plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2071.2
TW 1,5-4 BG
4044211048792
50
9
