10170.1
10170.1
    CONTA-CLIP
    插件,P=5mm
    接线端子 1x7P 5mm 直插 排数:单排 每排Pin数:7
10170.1 数据手册
Data sheet 10170.1 PK 500/7/5,00-H GN PCB terminal, Wire protection, No. of poles: 7, Width: 35.6 mm, Colour: Green Business data Article number 10170.1 Article name PK 500/7/5,00-H GN GTIN (EAN) 4044211003869 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 5.9 g Weight per piece (including packaging) 6.8 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 10170.1 Creation date 14.12.2023 20:06:43 Subject to technical changes 1 Data sheet 10170.1 PK 500/7/5,00-H GN Technical data Dimensions Length 10 mm Length of the pin 3.7 mm Width 35.6 mm Width left 3.1 mm Width right 2.5 mm Height 7.5 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 17.5 A Rated cross-section 1.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 14.12.2023 20:06:43 Subject to technical changes 2 Data sheet 10170.1 PK 500/7/5,00-H GN Technical data Connection data Connection principle Wire protection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 90° (vertically upwards) No. of poles 7 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 1.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 1.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 14 Stripping length 5 mm Screw threading M 2,6 Torque 0.4 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Wire protection Stainless steel Creation date 14.12.2023 20:06:43 Subject to technical changes 3 Data sheet 10170.1 PK 500/7/5,00-H GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 260 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 14.12.2023 20:06:43 Subject to technical changes 4 Data sheet 10170.1 PK 500/7/5,00-H GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 14 cUL wire cross-section stranded AWG, max. 22 cUL torque 0.400000006 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 14 UL wire cross-section stranded AWG, max. 22 UL torque 3.54 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 14.12.2023 20:06:43 Subject to technical changes 5 Data sheet 10170.1 PK 500/7/5,00-H GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 17.5 A VDE rated current wire cross-section rigid, max. 17.5 A VDE rated current wire cross-section stranded, max. 17.5 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 1.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1.5 mm² VDE screw threading M 2,6 VDE torque 0.4 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 20:06:43 Subject to technical changes 6 Data sheet 10170.1 PK 500/7/5,00-H GN Media Creation date 14.12.2023 20:06:43 Subject to technical changes 7 Data sheet 10170.1 PK 500/7/5,00-H GN Accessories Creation date 14.12.2023 20:06:43 Subject to technical changes 8
10170.1
物料型号:10170.1 PK 500/7/5,00-H GN
器件简介:该器件是一个7极的PCB端子,用于线缆保护,宽度为35.6毫米,颜色为绿色。
引脚分配:共有7个引脚,引脚间距为5毫米。
参数特性: - 额定电压:250V - 额定电流:17.5A - 额定截面积:1.5mm² - 额定脉冲电压:2kV - 过电压类别:III - 污染等级:3
功能详解: - 连接原理:线缆保护 - 连接类型:焊接连接 - 连接角度:90°(垂直向上) - 适用线缆截面积:单芯/绞合最小0.2mm²,最大1.5mm² - 剥离长度:5mm - 螺丝规格:M2.6 - 扭矩:0.4Nm
应用信息: - 工作温度范围:-30°C至105°C - 存储温度范围:-40°C至105°C - 绝缘电阻:110^13欧姆x厘米 - 爬电电流电阻:CTI 600 - 灼热丝可燃性指数GWFI:850°C - 灼热丝点燃温度GWIT:775°C
封装信息: - 绝缘体材料:聚酰胺6.6 - 阻燃等级:UL 94 V-0 - 固定元件材料:黄铜 - 螺丝材料:钢 - 线缆保护材料:不锈钢
10170.1 价格&库存
很抱歉,暂时无法提供与“10170.1”相匹配的价格&库存,您可以联系我们找货
    • 1+15.04440
    • 200+5.82120
    • 500+5.61600
    • 1000+5.51880
