Data sheet
1025.2 RKD 4/800V BG
Double-level terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated crosssection: 4 mm², Width: 7.5 mm, Colour: Beige
Business data
Article number
1025.2
Article name
RKD 4/800V BG
GTIN (EAN)
4044211005658
Packaging unit
80
Quantity unit
PC
Weight per piece (not including packaging)
16.8 g
Weight per piece (including packaging)
17.95 g
Unit of weight
G
Customs number
85369010
Country of origin
DE
Product description
Colour
Beige
Creation date 14.12.2023 20:10:51
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
60.2 mm
Width
7.5 mm
Height TS 35/7.5
61 mm
Height TS 32
65.5 mm
Ratings
Rated voltage
800 V
Rated current
32 A
Rated cross-section
4 mm²
Rated impulse voltage
6 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
2.05 W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
2x2
Number of terminals per level
2
Number of levels
2
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
4 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
12
Stripping length
9 mm
Screw head
Slotted
Screw threading
M3
Tightening torque, min.
0.5 Nm
Tightening torque, max.
1 Nm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Gauge plug acc. to EN 60 947-1
A4
End plate required
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
600 V
CSA Usegroup C: rated current
30 A
CSA wire cross-section AWG, min.
22
CSA wire cross-section AWG, max.
12
CSA stripping length
9 mm
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup C: rated voltage
600 V
CSAus Usegroup C: rated current
30 A
CSAus wire cross-section AWG, min.
22
CSAus wire cross-section AWG, max.
12
CSAus stripping length
9 mm
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
800 V
KEMA rated current
32 A
KEMA rated impulse voltage
6 kV
KEMA wire cross-section single core (rigid), min.
0.2 mm²
KEMA wire cross-section single-core (rigid), max.
4 mm²
KEMA wire cross-section stranded, min.
0.2 mm²
KEMA wire cross-section stranded, max.
4 mm²
4
Data sheet
Approvals
UL Recognized
UL approval
UL 1059
UL Usegroup C: rated voltage
600 V
UL Usegroup C: rated current
30 A
UL wire cross-section single-core (rigid) AWG, min.
22
UL wire cross-section single-core (rigid) AWG, max.
10
UL wire cross-section stranded AWG, min.
22
UL wire cross-section stranded AWG, max.
10
UL torque
7 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
5
Data sheet
Media
6
Data sheet
Accessories
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2159.2
AP 4 800 V BG
4044211049829
20 ST
End stop
End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2828.0
ES 35/K/ST BG
4044211055547
50
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4702.7
PMC SB 6/50 WH
4044211089986
500 ST
7
很抱歉,暂时无法提供与“1025.2”相匹配的价格&库存,您可以联系我们找货
