Data sheet
10262.1 PK 550/2/3,50-H GN
PCB terminal, Wire protection, No. of poles: 2, Width: 7 mm, Colour: Green
Business data
Article number
10262.1
Article name
PK 550/2/3,50-H GN
GTIN (EAN)
4044211005870
Packaging unit
50
Quantity unit
PC
Packaging type
Carton
Type of banding
Without
Weight per piece (not including packaging)
0.9 g
Weight per piece (including packaging)
1.35 g
Unit of weight
G
Customs number
85369010
Country of origin
TN
Prio-Article
10262.1
Creation date 14.12.2023 20:01:49
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
8.2 mm
Length of the pin
3.5 mm
Width
7 mm
Width left
1.75 mm
Width right
1.75 mm
Height
6.5 mm
Drill hole diameter
1.2 mm
Diameter of connecting pin
0.9 mm
Pitch
3.5 mm
Ratings
Rated voltage
130 V
Rated current
13.5 A
Rated cross-section
1 mm²
Rated impulse voltage
1.25 kV
Overvoltage category
III
Contamination degree
3
2
Data sheet
Technical data
Connection data
Connection principle
Wire protection
Connection type of PCB
Solder connection
Type of attachment to circuit board
Connecting contact
Angle of PCB/wire connection
90° (vertically upwards)
No. of poles
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.08 mm²
Wire cross-section single core (rigid)/stranded, max.
1.5 mm²
Wire cross-section stranded, min.
0.08 mm²
Wire cross-section stranded, max.
1 mm²
Wire cross-section stranded with wire-end ferrules,min.
0.14 mm²
Wire cross-section stranded with wire-end ferrules,max.
0.5 mm²
Wire cross-section AWG, min.
28
Wire cross-section AWG, max.
16
Stripping length
5.5 mm
Screw threading
M2
Torque
0.2 Nm
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-30 °C
Working temperature, max.
105 °C
Clamping element
Brass
Screws
Steel
Wire protection
Stainless steel
3
Data sheet
Technical data
Further technical data
Storage temperature, min.
-40 °C
Storage temperature, max.
105 °C
Insulation resistance
1*10^13 Ohm x cm
Creepage-current resistance
CTI 600
Glow wire flammability index GWFI
GWFI 850
GWFI after-glow time
30 Sek.
Glow wire ignition temperature GWIT
GWIT 775 °C
GWIT exposure time
5 Sek.
Connection cycles, in compliance with standard
5
Recommended wave soldering temperature
260 °C
Recommended wave soldering duration, min.
3 Sek.
Recommended wave soldering duration, max.
4 Sek.
Environmental Product Compliance
REACH Conform
No
REACH Candidate Substance Note
No
REACH CAS 1 Percent minimal
0.1 %
REACH CAS 1 Percent maximum
4%
REACH CAS 1 Number
7439-92-1
RoHS Exception rule
6c
4
Data sheet
Approvals
cUL Recognized
cUL approval
CSA 22.2 No.158
cUL Usegroup B: rated voltage
125 V
cUL Usegroup B: rated current
6A
cUL wire cross-section single-core (rigid) AWG, min.
28
cUL wire cross-section single-core (rigid) AWG, max. 16
cUL wire cross-section stranded AWG, min.
16
cUL wire cross-section stranded AWG, max.
28
cUL torque
0.25 Nm
cUL wire material
Cu
cUL Recognized
1
UL Recognized
UL approval
UL 1059
125 V
6A
28
16
16
28
UL torque
2.21 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
5
Data sheet
Approvals
VDE approval
VDE approval
DIN EN 60998
VDE approval granted
yes
VDE rated voltage
130 V
VDE rated current
13.5 A
VDE rated current wire cross-section rigid, max.
13.5 A
VDE rated current wire cross-section stranded, max.
13.5 A
VDE rated impulse voltage
1.25 kV
VDE wire cross-section rigid, min.
0.5 mm²
VDE wire cross-section rigid, max.
1 mm²
VDE wire cross-section stranded, min.
0.5 mm²
VDE wire cross-section stranded, max.
1 mm²
VDE screw threading
M2
VDE torque
0.2 Nm
VDE overvoltage category
III
VDE contamination degree
3
6
Data sheet
Media
7
Data sheet
Accessories
8
很抱歉,暂时无法提供与“10262.1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.78880
- 200+2.24640
- 500+2.16000
- 1000+2.12760
