10275.1
10275.1
    CONTA-CLIP
    插件,P=3.5mm
    接线端子 1x15P 3.5mm 直插 排数:单排 每排Pin数:15
10275.1 数据手册
Data sheet 10275.1 PK 550/15/3,50-H GN PCB terminal, Wire protection, No. of poles: 15, Width: 52.5 mm, Colour: Green Business data Article number 10275.1 Article name PK 550/15/3,50-H GN GTIN (EAN) 4044211006150 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 6.75 g Weight per piece (including packaging) 7.35 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 10275.1 Creation date 16.12.2023 16:09:30 Subject to technical changes 1 Data sheet 10275.1 PK 550/15/3,50-H GN Technical data Dimensions Length 8.2 mm Length of the pin 3.5 mm Width 52.5 mm Width left 1.75 mm Width right 1.75 mm Height 6.5 mm Drill hole diameter 1.2 mm Diameter of connecting pin 0.9 mm Pitch 3.5 mm Ratings Rated voltage 130 V Rated current 13.5 A Rated cross-section 1 mm² Rated impulse voltage 1.25 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 16:09:30 Subject to technical changes 2 Data sheet 10275.1 PK 550/15/3,50-H GN Technical data Connection data Connection principle Wire protection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 90° (vertically upwards) No. of poles 15 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.08 mm² Wire cross-section single core (rigid)/stranded, max. 1.5 mm² Wire cross-section stranded, min. 0.08 mm² Wire cross-section stranded, max. 1 mm² Wire cross-section stranded with wire-end ferrules,min. 0.14 mm² Wire cross-section stranded with wire-end ferrules,max. 0.5 mm² Wire cross-section AWG, min. 28 Wire cross-section AWG, max. 16 Stripping length 5.5 mm Screw threading M2 Torque 0.2 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Wire protection Stainless steel Creation date 16.12.2023 16:09:30 Subject to technical changes 3 Data sheet 10275.1 PK 550/15/3,50-H GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 260 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 16:09:30 Subject to technical changes 4 Data sheet 10275.1 PK 550/15/3,50-H GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 125 V cUL Usegroup B: rated current 6A cUL wire cross-section single-core (rigid) AWG, min. 28 cUL wire cross-section single-core (rigid) AWG, max. 16 cUL wire cross-section stranded AWG, min. 16 cUL wire cross-section stranded AWG, max. 28 cUL torque 0.25 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 125 V UL Usegroup B: rated current 6A UL wire cross-section single-core (rigid) AWG, min. 28 UL wire cross-section single-core (rigid) AWG, max. 16 UL wire cross-section stranded AWG, min. 16 UL wire cross-section stranded AWG, max. 28 UL torque 2.21 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 16:09:30 Subject to technical changes 5 Data sheet 10275.1 PK 550/15/3,50-H GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 130 V VDE rated current 13.5 A VDE rated current wire cross-section rigid, max. 13.5 A VDE rated current wire cross-section stranded, max. 13.5 A VDE rated impulse voltage 1.25 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 1 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1 mm² VDE screw threading M2 VDE torque 0.2 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 16:09:30 Subject to technical changes 6 Data sheet 10275.1 PK 550/15/3,50-H GN Media Creation date 16.12.2023 16:09:30 Subject to technical changes 7 Data sheet 10275.1 PK 550/15/3,50-H GN Accessories Creation date 16.12.2023 16:09:30 Subject to technical changes 8
10275.1
1. 物料型号:10275.1 PK 550/15/3,50-H GN 2. 器件简介:这是一个PCB端子,用于电线保护,具有15个极,宽度为52.5毫米,颜色为绿色。 3. 引脚分配:文档中未明确列出每个引脚的具体功能,但提供了连接原理和类型,例如连接类型为焊接连接,连接角度为90°垂直向上。 4. 参数特性:包括尺寸、额定电压130V、额定电流13.5A、额定截面积1mm²、额定脉冲电压1.25kV等。 5. 功能详解:提供了连接数据,如电线截面积范围、剥离长度、螺丝规格等。 6. 应用信息:包括存储温度范围、绝缘电阻、爬电电流电阻、灼热丝可燃性指数等。 7. 封装信息:材料包括聚酰胺6.6绝缘体、黄铜夹持元件、不锈钢线保护等,工作温度范围为-30°C至105°C。 8. 认证信息:包括cUL、CSA、UL和VDE认证的详细信息。
10275.1 价格&库存
很抱歉,暂时无法提供与“10275.1”相匹配的价格&库存,您可以联系我们找货
