10498.1
10498.1
    CONTA-CLIP
    插件,P=5mm
    接线端子 5mm 插件
10498.1 数据手册
Data sheet 10498.1 PKD 750/11/5,00-V GN Double-level PCB terminal, Screw connection, No. of poles: 11, Width: 58.1 mm, Colour: Green Business data Article number 10498.1 Article name PKD 750/11/5,00-V GN GTIN (EAN) 4044211010430 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 53.52 g Weight per piece (including packaging) 54.62 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 10498.1 Creation date 16.12.2023 19:26:54 Subject to technical changes 1 Data sheet 10498.1 PKD 750/11/5,00-V GN Technical data Dimensions Length 21.5 mm Length of the pin 4 mm Width 58.1 mm Width left 3.1 mm Width right 5 mm Height 34 mm Drill hole diameter 1.3 mm Diameter of connecting pin 0.9 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 19:26:54 Subject to technical changes 2 Data sheet 10498.1 PKD 750/11/5,00-V GN Technical data Connection data Connection principle Screw connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) Number of electrical connections 22 No. of poles 11 Number of levels 2 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 30 Wire cross-section AWG, max. 12 Stripping length 8 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Soldering lug Copper alloy Creation date 16.12.2023 19:26:54 Subject to technical changes 3 Data sheet 10498.1 PKD 750/11/5,00-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 19:26:54 Subject to technical changes 4 Data sheet 10498.1 PKD 750/11/5,00-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 30 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 30 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 30 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 30 UL wire cross-section stranded AWG, max. 12 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 19:26:54 Subject to technical changes 5 Data sheet 10498.1 PKD 750/11/5,00-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 4 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:26:54 Subject to technical changes 6 Data sheet 10498.1 PKD 750/11/5,00-V GN Media Creation date 16.12.2023 19:26:54 Subject to technical changes 7 Data sheet 10498.1 PKD 750/11/5,00-V GN Accessories Creation date 16.12.2023 19:26:54 Subject to technical changes 8
10498.1
物料型号:10498.1 PKD 750/11/5,00-V GN
器件简介:双层面PCB端子,螺丝连接,11个极,宽度58.1毫米,颜色为绿色。
引脚分配:共有22个电气连接,11个极,分为两个层面。
参数特性: - 额定电压:250V - 额定电流:24A - 额定截面积:2.5 mm² - 额定脉冲电压:2kV - 污染等级:3
功能详解: - 连接原理:螺丝连接 - PCB连接类型:焊接 - 连接角度:0°/180°(水平) - 导线截面积范围:单芯(刚性)/绞合,最小0.2 mm²,最大4 mm² - 螺丝规格:M3 - 扭矩:0.5 Nm
应用信息:适用于需要双层面PCB端子的电气连接。
封装信息: - 绝缘体材料:聚酰胺6.6 - 阻燃等级:UL 94 V-0 - 工作温度范围:-30°C 至 105°C - 压接元件:黄铜 - 螺丝:钢 - 焊盘:铜合金
10498.1 价格&库存
很抱歉,暂时无法提供与“10498.1”相匹配的价格&库存,您可以联系我们找货
