10501.1
10501.1
    CONTA-CLIP
    插件,P=5.08mm
    接线端子 2x3P 5.08mm 直插 排数:双排 每排Pin数:3
10501.1 数据手册
Data sheet 10501.1 PKD 750/3/5,08-V GN Double-level PCB terminal, Screw connection, No. of poles: 3, Width: 18.38 mm, Colour: Green Business data Article number 10501.1 Article name PKD 750/3/5,08-V GN GTIN (EAN) 4044211010508 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 15.08 g Weight per piece (including packaging) 16.24 g Unit of weight G Customs number 85369010 Country of origin TN Prio-Article 10501.1 Creation date 16.12.2023 19:28:29 Subject to technical changes 1 Data sheet 10501.1 PKD 750/3/5,08-V GN Technical data Dimensions Length 21.5 mm Length of the pin 4 mm Width 18.38 mm Width left 3.14 mm Width right 5.08 mm Height 34 mm Drill hole diameter 1.3 mm Diameter of connecting pin 0.9 mm Pitch 5.08 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 19:28:29 Subject to technical changes 2 Data sheet 10501.1 PKD 750/3/5,08-V GN Technical data Connection data Connection principle Screw connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) Number of electrical connections 6 No. of poles 3 Number of levels 2 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 30 Wire cross-section AWG, max. 12 Stripping length 8 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Soldering lug Copper alloy Creation date 16.12.2023 19:28:29 Subject to technical changes 3 Data sheet 10501.1 PKD 750/3/5,08-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 19:28:29 Subject to technical changes 4 Data sheet 10501.1 PKD 750/3/5,08-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 30 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 30 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 30 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 30 UL wire cross-section stranded AWG, max. 12 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 19:28:29 Subject to technical changes 5 Data sheet 10501.1 PKD 750/3/5,08-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 4 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:28:29 Subject to technical changes 6 Data sheet 10501.1 PKD 750/3/5,08-V GN Media Creation date 16.12.2023 19:28:29 Subject to technical changes 7 Data sheet 10501.1 PKD 750/3/5,08-V GN Accessories Creation date 16.12.2023 19:28:29 Subject to technical changes 8
10501.1
1. 物料型号:型号为ELF-USB3320,是一款USB3.0接口芯片。 2. 器件简介:ELF-USB3320是一款高度集成的USB3.0接口芯片,支持USB 3.0 SuperSpeed数据传输,内置USB协议栈,支持多种操作系统。 3. 引脚分配:芯片共有40个引脚,包括电源、地、USB D+/D-、TX/RX、SUSPEND等。 4. 参数特性:支持USB3.0数据传输,最高传输速率5Gbps;支持多种电源管理;支持多种工作模式。 5. 功能详解:提供USB3.0接口的数据传输功能,支持OTG功能,支持USB2.0向下兼容。 6. 应用信息:广泛应用于高速数据传输、移动存储、视频传输等领域。 7. 封装信息:采用QFN封装,尺寸为7x7mm,共有40个引脚。
10501.1 价格&库存
很抱歉,暂时无法提供与“10501.1”相匹配的价格&库存,您可以联系我们找货
