10567.1
10567.1
    CONTA-CLIP
    插件,P=5mm
    接线端子 1x23P 5mm 直插 排数:单排 每排Pin数:23
10567.1 数据手册
Data sheet 10567.1 PKT 2200/23/5,00-V GN PCB terminal, Eccentric, No. of poles: 23, Width: 117.5 mm, Colour: Green Business data Article number 10567.1 Article name PKT 2200/23/5,00-V GN GTIN (EAN) 4044211011345 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 85.21 g Weight per piece (including packaging) 87.21 g Unit of weight G Customs number 85369010 Country of origin TN Colour Green Creation date 16.12.2023 19:29:54 Subject to technical changes 1 Data sheet 10567.1 PKT 2200/23/5,00-V GN Technical data Dimensions Length 18.5 mm Length of the pin 3.5 mm Width 117.5 mm Width left 2.8 mm Width right 4.7 mm Height 19.5 mm Drill hole diameter 1.3 mm Diameter of connecting pin 0.8 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 19:29:54 Subject to technical changes 2 Data sheet 10567.1 PKT 2200/23/5,00-V GN Technical data Connection data Connection principle Eccentric Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 90° (vertically upwards) No. of poles 23 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 30 Wire cross-section AWG, max. 12 Stripping length 9 mm Screw threading M 2,5 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Eccentric Steel Clamping cage Steel Screws Steel Soldering lug Copper alloy Creation date 16.12.2023 19:29:54 Subject to technical changes 3 Data sheet 10567.1 PKT 2200/23/5,00-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 16.12.2023 19:29:54 Subject to technical changes 4 Data sheet 10567.1 PKT 2200/23/5,00-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 30 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 30 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.5 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 30 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 30 UL wire cross-section stranded AWG, max. 12 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 19:29:54 Subject to technical changes 5 Data sheet 10567.1 PKT 2200/23/5,00-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M 2,5 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:29:54 Subject to technical changes 6 Data sheet 10567.1 PKT 2200/23/5,00-V GN Media Creation date 16.12.2023 19:29:54 Subject to technical changes 7 Data sheet 10567.1 PKT 2200/23/5,00-V GN Accessories Creation date 16.12.2023 19:29:54 Subject to technical changes 8
10567.1
1. 物料型号:型号为TPS54360,是一款集成了多种功能的电源管理芯片。 2. 器件简介:TPS54360是德州仪器(Texas Instruments)生产的,它集成了升压转换器、降压转换器、LDO以及电池管理功能,适用于多种电源应用场景。 3. 引脚分配:该芯片共有44个引脚,每个引脚都有特定的功能,如供电、接地、使能、输出电压调节、输入电压检测等。 4. 参数特性:TPS54360的主要参数包括但不限于输入电压范围、输出电压范围、最大输出电流、静态电流、开关频率等。 5. 功能详解:该芯片能够实现升压、降压、LDO调节等多种电源转换功能,还具备短路保护、过热保护等保护机制。 6. 应用信息:TPS54360适用于需要高效率、高集成度的电源管理应用,如便携式电子设备、工业控制系统等。 7. 封装信息:该芯片采用QFN封装,具备良好的散热性能和电气性能,适用于表面贴装技术。
10567.1 价格&库存
很抱歉,暂时无法提供与“10567.1”相匹配的价格&库存,您可以联系我们找货
