10628.1
10628.1
    CONTA-CLIP
    插件,P=7.5mm
    接线端子 1x12P 7.5mm 直插 排数:单排 每排Pin数:12
10628.1 数据手册
Data sheet 10628.1 PKT 2200/12/7,50-H GN PCB terminal, Eccentric, No. of poles: 12, Width: 90 mm, Colour: Green Business data Article number 10628.1 Article name PKT 2200/12/7,50-H GN GTIN (EAN) 4044211012007 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 48.98 g Weight per piece (including packaging) 51.98 g Unit of weight G Customs number 85369010 Country of origin QU Colour Green Creation date 16.12.2023 19:30:12 Subject to technical changes 1 Data sheet 10628.1 PKT 2200/12/7,50-H GN Technical data Dimensions Length 19.5 mm Length of the pin 3.5 mm Width 90 mm Width left 2.8 mm Width right 4.7 mm Height 18.5 mm Drill hole diameter 1.3 mm Diameter of connecting pin 0.8 mm Pitch 7.5 mm Ratings Rated voltage 450 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2.5 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 19:30:12 Subject to technical changes 2 Data sheet 10628.1 PKT 2200/12/7,50-H GN Technical data Connection data Connection principle Eccentric Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) No. of poles 12 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 30 Wire cross-section AWG, max. 12 Stripping length 9 mm Screw threading M 2,5 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Eccentric Steel Clamping cage Steel Screws Steel Soldering lug Copper alloy Creation date 16.12.2023 19:30:12 Subject to technical changes 3 Data sheet 10628.1 PKT 2200/12/7,50-H GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 16.12.2023 19:30:12 Subject to technical changes 4 Data sheet 10628.1 PKT 2200/12/7,50-H GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 30 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 30 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.5 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 30 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 30 UL wire cross-section stranded AWG, max. 12 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 19:30:12 Subject to technical changes 5 Data sheet 10628.1 PKT 2200/12/7,50-H GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 450 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2.5 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M 2,5 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:30:12 Subject to technical changes 6 Data sheet 10628.1 PKT 2200/12/7,50-H GN Media Creation date 16.12.2023 19:30:12 Subject to technical changes 7 Data sheet 10628.1 PKT 2200/12/7,50-H GN Accessories Creation date 16.12.2023 19:30:12 Subject to technical changes 8
10628.1 价格&库存
很抱歉,暂时无法提供与“10628.1”相匹配的价格&库存,您可以联系我们找货
