1064.2
1064.2
    CONTA-CLIP
    EARTH TERMINAL
1064.2 数据手册
Data sheet 1064.2 SL 4/15 GNYE Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4 mm², Width: 7 mm, Colour: Green-yellow Business data Article number 1064.2 Article name SL 4/15 GNYE GTIN (EAN) 4044211012144 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 14 g Weight per piece (including packaging) 14.5 g Unit of weight G Customs number 85369010 Country of origin CZ Product description Protective earth terminal Colour Green-yellow Creation date 16.12.2023 18:51:57 Subject to technical changes 1 Data sheet 1064.2 SL 4/15 GNYE Technical data Dimensions Length 32 mm Width 7 mm Height TS 15/5.5 34 mm Ratings Rated cross-section 4 mm² Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 10 Stripping length 9 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Creation date 16.12.2023 18:51:57 Subject to technical changes 2 Data sheet 1064.2 SL 4/15 GNYE Technical data Further technical data Mounting type TS 15 Gauge plug acc. to EN 60 947-1 A3 Tightening torque, fastening screw max. 1 Nm Tightening torque, fastening screw min. 0.5 Nm Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 18:51:57 Subject to technical changes 3 Data sheet 1064.2 SL 4/15 GNYE Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes cUL Recognized cUL approval C22.2 No 158 cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 10 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 10 cUL torque 7 Nm cUL wire material Cu cUL File Number E95701 cUL Recognized 1 KEMA KEUR approval KEMA KEUR approval EN 60947-7-2:2009 KEMA KEUR approval granted yes KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² UL Recognized UL approval UL 1059 UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 10 UL torque 7 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL File Number E95701 UL Recognized 1 Creation date 16.12.2023 18:51:57 Subject to technical changes 4 Data sheet 1064.2 SL 4/15 GNYE Media Creation date 16.12.2023 18:51:57 Subject to technical changes 5 Data sheet 1064.2 SL 4/15 GNYE Accessories Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Creation date 16.12.2023 18:51:57 Subject to technical changes 6
1064.2 价格&库存
很抱歉,暂时无法提供与“1064.2”相匹配的价格&库存,您可以联系我们找货
