1069
1069
    CONTA-CLIP
    FERRULES
1069 数据手册
Data sheet 1069.0 H 2,5/14-T GR Wire-end ferrules, Max. wire cross-section: 2.5 mm², Length: 15 mm, Length of copper pipe: 8 mm, Colour: Grey RAL: 7032 Business data Article number 1069.0 Article name H 2,5/14-T GR GTIN (EAN) 4044211012663 Packaging unit 500 Quantity unit PC Weight per piece (not including packaging) 0.14 g Weight per piece (including packaging) 0.15 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour Grey Creation date 14.12.2023 20:55:08 Subject to technical changes 1 Data sheet 1069.0 H 2,5/14-T GR Technical data Dimensions Length 15 mm Length of copper pipe 8 mm Diameter of copper pipe 2.2 mm Diameter plastic collar 4.2 mm Wall thickness of copper pipe 0.15 mm Wall thickness of plastic collar 0.25 mm Connection data Wire cross-section, max. 2.5 mm² Wire cross-section AWG, max. 14 Stripping length 10 mm Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Plastic collar Polypropylene homopolymer Working temperature, min. -5 °C Working temperature, max. 105 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 20:55:08 Subject to technical changes 2 Data sheet 1069.0 H 2,5/14-T GR Approvals Standards and regulations DIN 46228-4:1990 Creation date 14.12.2023 20:55:08 yes Subject to technical changes 3 Data sheet 1069.0 H 2,5/14-T GR Media Creation date 14.12.2023 20:55:08 Subject to technical changes 4 Data sheet 1069.0 H 2,5/14-T GR Accessories Creation date 14.12.2023 20:55:08 Subject to technical changes 5
很抱歉,暂时无法提供与“1069”相匹配的价格&库存,您可以联系我们找货
