10696.0
10696.0
    CONTA-CLIP
    插件
    接线端子
10696.0 数据手册
Data sheet 10696.0 PZK 3000/8/5,00/5,08 LG PCB terminal, Tension-spring connection, No. of poles: 8, Width: 42.2 mm, Colour: Pebble grey Business data Article number 10696.0 Article name PZK 3000/8/5,00/5,08 LG GTIN (EAN) 4044211012793 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 6.9 g Weight per piece (including packaging) 8.45 g Unit of weight G Customs number 85369010 Country of origin TN Prio-Article 10696.1 Creation date 16.12.2023 19:31:02 Subject to technical changes 1 Data sheet 10696.0 PZK 3000/8/5,00/5,08 LG Technical data Dimensions Length 14.2 mm Length of the pin 4 mm Width 42.2 mm Width left 3.65 mm Width right 3.55 mm Height 12.9 mm Drill hole diameter 1.1 mm Diameter of connecting pin 0.7 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Tension-spring connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 45°/135° (slanted upwards) No. of poles 8 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.08 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.14 mm² Wire cross-section stranded with wire-end ferrules, max. 1.5 mm² Wire cross-section AWG, min. 28 Wire cross-section AWG, max. 14 Stripping length 6 mm Creation date 16.12.2023 19:31:02 Subject to technical changes 2 Data sheet 10696.0 PZK 3000/8/5,00/5,08 LG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Tension spring Stainless steel Soldering lug Copper alloy Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 10 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 19:31:02 No Subject to technical changes 3 Data sheet 10696.0 PZK 3000/8/5,00/5,08 LG Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 28 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 28 cUL wire cross-section stranded AWG, max. 14 cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 28 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 28 UL wire cross-section stranded AWG, max. 14 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 19:31:02 Subject to technical changes 4 Data sheet 10696.0 PZK 3000/8/5,00/5,08 LG Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:31:02 Subject to technical changes 5 Data sheet 10696.0 PZK 3000/8/5,00/5,08 LG Media Creation date 16.12.2023 19:31:02 Subject to technical changes 6 Data sheet 10696.0 PZK 3000/8/5,00/5,08 LG Accessories Creation date 16.12.2023 19:31:02 Subject to technical changes 7
10696.0 价格&库存
很抱歉,暂时无法提供与“10696.0”相匹配的价格&库存,您可以联系我们找货
    • 1+18.74880
    • 200+7.25760
    • 500+7.00920
    • 1000+6.87960
