10752.0
10752.0
    CONTA-CLIP
    插件
    接线端子
10752.0 数据手册
Data sheet 10752.0 PZK 3010/16/7,50/7,62 LG PCB terminal, Tension-spring connection, No. of poles: 16, Width: 122.2 mm, Colour: Pebble grey Business data Article number 10752.0 Article name PZK 3010/16/7,50/7,62 LG GTIN (EAN) 4044211013561 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 16.6 g Weight per piece (including packaging) 18.1 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 10752.1 Creation date 16.12.2023 19:30:19 Subject to technical changes 1 Data sheet 10752.0 PZK 3010/16/7,50/7,62 LG Technical data Dimensions Length 14.2 mm Length of the pin 4 mm Width 122.2 mm Width left 3.65 mm Width right 6.05 mm Height 12.9 mm Drill hole diameter 1.1 mm Diameter of connecting pin 0.7 mm Pitch 7.5 mm Ratings Rated voltage 750 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 3 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Tension-spring connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 45°/135° (slanted upwards) No. of poles 16 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.08 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.14 mm² Wire cross-section stranded with wire-end ferrules, max. 1.5 mm² Wire cross-section AWG, min. 28 Wire cross-section AWG, max. 14 Stripping length 6 mm Creation date 16.12.2023 19:30:19 Subject to technical changes 2 Data sheet 10752.0 PZK 3010/16/7,50/7,62 LG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Tension spring Stainless steel Soldering lug Copper alloy Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 10 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 19:30:19 No Subject to technical changes 3 Data sheet 10752.0 PZK 3010/16/7,50/7,62 LG Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 16 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 28 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 28 cUL wire cross-section stranded AWG, max. 14 cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 16 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 28 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 28 UL wire cross-section stranded AWG, max. 14 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 19:30:19 Subject to technical changes 4 Data sheet 10752.0 PZK 3010/16/7,50/7,62 LG Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 750 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 3 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:30:19 Subject to technical changes 5 Data sheet 10752.0 PZK 3010/16/7,50/7,62 LG Media Creation date 16.12.2023 19:30:19 Subject to technical changes 6 Data sheet 10752.0 PZK 3010/16/7,50/7,62 LG Accessories Creation date 16.12.2023 19:30:19 Subject to technical changes 7
10752.0 价格&库存
很抱歉,暂时无法提供与“10752.0”相匹配的价格&库存,您可以联系我们找货
