10799.1
10799.1
    CONTA-CLIP
    插件
    接线端子
10799.1 数据手册
Data sheet 10799.1 PZK 3001/15/5,00/5,08-KD GN PCB terminal, Tension-spring connection, No. of poles: 15, Width: 77.9 mm, Colour: Green Business data Article number 10799.1 Article name PZK 3001/15/5,00/5,08-KD GN GTIN (EAN) 4044211014070 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 13.9 g Weight per piece (including packaging) 15.2 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 10799.1 Creation date 16.12.2023 19:33:42 Subject to technical changes 1 Data sheet 10799.1 PZK 3001/15/5,00/5,08-KD GN Technical data Dimensions Length 14.2 mm Length of the pin 4 mm Width 77.9 mm Width left 3.65 mm Width right 4.25 mm Height 12.9 mm Drill hole diameter 1.1 mm Diameter of connecting pin 0.7 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Tension-spring connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 45°/135° (slanted upwards) No. of poles 15 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.08 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.14 mm² Wire cross-section stranded with wire-end ferrules, max. 1.5 mm² Wire cross-section AWG, min. 28 Wire cross-section AWG, max. 14 Stripping length 6 mm Creation date 16.12.2023 19:33:42 Subject to technical changes 2 Data sheet 10799.1 PZK 3001/15/5,00/5,08-KD GN Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Tension spring Stainless steel Soldering lug Copper alloy Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 10 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 19:33:42 No Subject to technical changes 3 Data sheet 10799.1 PZK 3001/15/5,00/5,08-KD GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 28 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 28 cUL wire cross-section stranded AWG, max. 14 cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 28 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 28 UL wire cross-section stranded AWG, max. 14 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 19:33:42 Subject to technical changes 4 Data sheet 10799.1 PZK 3001/15/5,00/5,08-KD GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:33:42 Subject to technical changes 5 Data sheet 10799.1 PZK 3001/15/5,00/5,08-KD GN Media Creation date 16.12.2023 19:33:42 Subject to technical changes 6 Data sheet 10799.1 PZK 3001/15/5,00/5,08-KD GN Accessories Creation date 16.12.2023 19:33:42 Subject to technical changes 7
10799.1
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电开关,具有高灵敏度和高抗干扰能力,适用于工业自动化控制、传感器信号隔离等场景。
3. 引脚分配:EL817共有6个引脚,分别为VCC、OUT、GND、A、B、C。
4. 参数特性:工作电压范围为3.3V-5.5V,输出电流最大为50mA,响应时间小于10ms。
5. 功能详解:EL817通过光电转换实现信号隔离,提高系统稳定性和抗干扰能力。
6. 应用信息:广泛应用于工业自动化、传感器信号隔离、医疗设备等领域。
7. 封装信息:EL817采用6引脚SOP封装。
10799.1 价格&库存
很抱歉,暂时无法提供与“10799.1”相匹配的价格&库存,您可以联系我们找货
