1089.0
1089.0
    CONTA-CLIP
    FERRULES
1089.0 数据手册
Data sheet 1089.0 H 2,5/24-T GR Wire-end ferrules, Max. wire cross-section: 2.5 mm², Length: 25 mm, Length of copper pipe: 18 mm, Colour: Grey RAL: 7032 Business data Article number 1089.0 Article name H 2,5/24-T GR GTIN (EAN) 4044211015008 Packaging unit 500 Quantity unit PC Weight per piece (not including packaging) 0.2 g Weight per piece (including packaging) 0.25 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour Grey Creation date 16.12.2023 16:36:23 Subject to technical changes 1 Data sheet 1089.0 H 2,5/24-T GR Technical data Dimensions Length 25 mm Length of copper pipe 18 mm Diameter of copper pipe 2.2 mm Diameter plastic collar 4.2 mm Wall thickness of copper pipe 0.15 mm Wall thickness of plastic collar 0.25 mm Connection data Wire cross-section, max. 2.5 mm² Wire cross-section AWG, max. 14 Stripping length 20 mm Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Plastic collar Polypropylene homopolymer Working temperature, min. -5 °C Working temperature, max. 105 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 16:36:23 Subject to technical changes 2 Data sheet 1089.0 H 2,5/24-T GR Approvals Standards and regulations DIN 46228-4:1990 Creation date 16.12.2023 16:36:23 yes Subject to technical changes 3 Data sheet 1089.0 H 2,5/24-T GR Media Creation date 16.12.2023 16:36:23 Subject to technical changes 4 Data sheet 1089.0 H 2,5/24-T GR Accessories Creation date 16.12.2023 16:36:23 Subject to technical changes 5
1089.0 价格&库存
很抱歉,暂时无法提供与“1089.0”相匹配的价格&库存,您可以联系我们找货
