11171.1
11171.1
    CONTA-CLIP
    接线端子
11171.1 数据手册
Data sheet 11171.1 PKB 130/4/5,00 GN Female socket block, Wire protection, No. of poles: 4, Width: 20.7 mm, Colour: Green Business data Article number 11171.1 Article name PKB 130/4/5,00 GN GTIN (EAN) 4044211018023 Connector version Free connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 3.7 g Weight per piece (including packaging) 4.16 g Unit of weight G Customs number 85366930 Country of origin TN Prio-Article 11171.1 Creation date 16.12.2023 19:34:44 Subject to technical changes 1 Data sheet 11171.1 PKB 130/4/5,00 GN Technical data Dimensions Length 10.8 mm Width 20.7 mm Width left 2.5 mm Width right 3.2 mm Height 13.5 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 7A Rated cross-section 1.5 mm² Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Wire protection Angle of wire connection/contact 0°/180° (horizontal) Number of plug-in rows 1 No. of poles 4 Contact version Female connector Wire cross-section single-core (rigid) / stranded, min. 0.14 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.14 mm² Wire cross-section stranded with wire-end ferrules, max. 1.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 14 Stripping length 6 mm Screw threading M 2,6 Torque 0.4 Nm Creation date 16.12.2023 19:34:44 Subject to technical changes 2 Data sheet 11171.1 PKB 130/4/5,00 GN Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Contact spring Copper alloy Screws Steel Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Plug-in cycles acc. to standard 100 Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 19:34:44 Subject to technical changes 3 Data sheet 11171.1 PKB 130/4/5,00 GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 8A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 8A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 8A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 14 cUL torque 0.45 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 8A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 8A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 8A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 14 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 19:34:44 Subject to technical changes 4 Data sheet 11171.1 PKB 130/4/5,00 GN Approvals VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 7A VDE rated current wire cross-section rigid, min. 5A VDE rated current wire cross-section rigid, max. 7A VDE rated current wire cross-section stranded, min. 5A VDE rated current wire cross-section stranded, max. 7A VDE rated impulse voltage 4 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1.5 mm² VDE screw threading M 2,6 VDE torque 0.4 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:34:44 Subject to technical changes 5 Data sheet 11171.1 PKB 130/4/5,00 GN Media Creation date 16.12.2023 19:34:44 Subject to technical changes 6 Data sheet 11171.1 PKB 130/4/5,00 GN Accessories Creation date 16.12.2023 19:34:44 Subject to technical changes 7
11171.1 价格&库存
很抱歉,暂时无法提供与“11171.1”相匹配的价格&库存,您可以联系我们找货
  • 50+10.4411450+1.33929
