Data sheet
11180.4 PKB 130/2/10,00 DG
Female socket block, Wire protection, No. of poles: 2, Width: 15.7 mm, Colour: Dark grey
Business data
Article number
11180.4
Article name
PKB 130/2/10,00 DG
GTIN (EAN)
4044211018221
Connector version
Free connector
Packaging unit
50
Quantity unit
PC
Packaging type
Carton
Type of banding
Without
Weight per piece (not including packaging)
2.1 g
Weight per piece (including packaging)
2.5 g
Unit of weight
G
Customs number
85366930
Country of origin
QU
Prio-Article
11180.1
Creation date 16.12.2023 19:33:59
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
10.8 mm
Width
15.7 mm
Width left
2.5 mm
Width right
3.2 mm
Height
13.5 mm
Pitch
10 mm
Ratings
Rated voltage
630 V
Rated current
7A
Rated cross-section
2.5 mm²
Rated impulse voltage
6 kV
Overvoltage category
III
Contamination degree
3
Connection data
Connection principle
Wire protection
Angle of wire connection/contact
0°/180° (horizontal)
Number of plug-in rows
1
No. of poles
2
Contact version
Female connector
Wire cross-section single-core (rigid) / stranded, min.
0.14 mm²
Wire cross-section single core (rigid)/stranded, max.
2.5 mm²
Wire cross-section stranded, min.
0.14 mm²
Wire cross-section stranded, max.
1.5 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.14 mm²
max.
1.5 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
14
Stripping length
6 mm
Screw threading
M 2,6
Torque
0.4 Nm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-30 °C
Working temperature, max.
105 °C
Clamping element
Brass
Contact spring
Copper alloy
Screws
Steel
Further technical data
Storage temperature, min.
-40 °C
Storage temperature, max.
105 °C
Insulation resistance
1*10^13 Ohm x cm
Creepage-current resistance
CTI 600
Glow wire flammability index GWFI
GWFI 850
GWFI after-glow time
30 Sek.
Glow wire ignition temperature GWIT
GWIT 775 °C
GWIT exposure time
5 Sek.
Connection cycles, in compliance with standard
5
Plug-in cycles acc. to standard
100
Environmental Product Compliance
REACH Conform
No
REACH Candidate Substance Note
No
REACH CAS 1 Percent minimal
0.1 %
REACH CAS 1 Percent maximum
4%
REACH CAS 1 Number
7439-92-1
RoHS Exception rule
6c
3
Data sheet
Approvals
cUL Recognized
cUL approval
CSA 22.2 No.158
cUL Usegroup B: rated voltage
300 V
cUL Usegroup B: rated current
8A
cUL Usegroup C: rated voltage
150 V
cUL Usegroup C: rated current
8A
cUL Usegroup D: rated voltage
300 V
cUL Usegroup D: rated current
8A
cUL wire cross-section single-core (rigid) AWG, min.
22
cUL wire cross-section single-core (rigid) AWG, max. 14
cUL wire cross-section stranded AWG, min.
22
cUL wire cross-section stranded AWG, max.
14
cUL torque
0.45 Nm
cUL wire material
Cu
cUL Recognized
1
UL Recognized
UL approval
UL 1059
300 V
8A
150 V
8A
300 V
8A
22
14
22
14
UL torque
4 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
4
Data sheet
Approvals
VDE approval
VDE approval
DIN EN 61984
VDE approval granted
yes
VDE rated voltage
630 V
VDE rated current
7A
VDE rated current wire cross-section rigid, min.
5A
VDE rated current wire cross-section rigid, max.
7A
VDE rated current wire cross-section stranded, min.
5A
VDE rated current wire cross-section stranded, max.
7A
VDE rated impulse voltage
6 kV
VDE wire cross-section rigid, min.
0.5 mm²
VDE wire cross-section rigid, max.
2.5 mm²
VDE wire cross-section stranded, min.
0.5 mm²
VDE wire cross-section stranded, max.
2.5 mm²
VDE screw threading
M 2,6
VDE torque
0.4 Nm
VDE overvoltage category
III
VDE contamination degree
3
5
Data sheet
Media
6
Data sheet
Accessories
7
很抱歉,暂时无法提供与“11180.4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+7.3736450+0.95577
