11183.4
11183.4
    CONTA-CLIP
    接线端子 自由悬挂(直插式)
11183.4 数据手册
Data sheet 11183.4 PKB 130/5/10,00 DG Female socket block, Wire protection, No. of poles: 5, Width: 45.7 mm, Colour: Dark grey Business data Article number 11183.4 Article name PKB 130/5/10,00 DG GTIN (EAN) 4044211018306 Connector version Free connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 5g Weight per piece (including packaging) 5.6 g Unit of weight G Customs number 85366930 Country of origin TN Prio-Article 11183.1 Creation date 16.12.2023 19:34:17 Subject to technical changes 1 Data sheet 11183.4 PKB 130/5/10,00 DG Technical data Dimensions Length 10.8 mm Width 45.7 mm Width left 2.5 mm Width right 3.2 mm Height 13.5 mm Pitch 10 mm Ratings Rated voltage 630 V Rated current 7A Rated cross-section 2.5 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Wire protection Angle of wire connection/contact 0°/180° (horizontal) Number of plug-in rows 1 No. of poles 5 Contact version Female connector Wire cross-section single-core (rigid) / stranded, min. 0.14 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.14 mm² Wire cross-section stranded with wire-end ferrules, max. 1.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 14 Stripping length 6 mm Screw threading M 2,6 Torque 0.4 Nm Creation date 16.12.2023 19:34:17 Subject to technical changes 2 Data sheet 11183.4 PKB 130/5/10,00 DG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Contact spring Copper alloy Screws Steel Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Plug-in cycles acc. to standard 100 Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 19:34:17 Subject to technical changes 3 Data sheet 11183.4 PKB 130/5/10,00 DG Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 8A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 8A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 8A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 14 cUL torque 0.45 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 8A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 8A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 8A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 14 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 19:34:17 Subject to technical changes 4 Data sheet 11183.4 PKB 130/5/10,00 DG Approvals VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 630 V VDE rated current 7A VDE rated current wire cross-section rigid, min. 5A VDE rated current wire cross-section rigid, max. 7A VDE rated current wire cross-section stranded, min. 5A VDE rated current wire cross-section stranded, max. 7A VDE rated impulse voltage 6 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M 2,6 VDE torque 0.4 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:34:17 Subject to technical changes 5 Data sheet 11183.4 PKB 130/5/10,00 DG Media Creation date 16.12.2023 19:34:17 Subject to technical changes 6 Data sheet 11183.4 PKB 130/5/10,00 DG Accessories Creation date 16.12.2023 19:34:17 Subject to technical changes 7
11183.4 价格&库存
很抱歉,暂时无法提供与“11183.4”相匹配的价格&库存,您可以联系我们找货
