1126.6
1126.6
    CONTA-CLIP
    FEED-THROUGH TERMINAL
1126.6 数据手册
Data sheet 1126.6 RK 240 GR Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated crosssection: 240 mm², Width: 36 mm, Colour: Grey RAL: 7030 Business data Article number 1126.6 Article name RK 240 GR GTIN (EAN) 4044211127442 Packaging unit 5 Quantity unit PC Weight per piece (not including packaging) 352.4 g Weight per piece (including packaging) 373.6 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 1126.2 Product description Feed-through terminal Creation date 16.12.2023 19:36:14 Subject to technical changes 1 Data sheet 1126.6 RK 240 GR Technical data Dimensions Length 93 mm Width 36 mm Height TS 35/7.5 126.3 mm Height TS 32 132 mm Ratings Rated voltage 1000 V Rated current 415 A Rated cross-section 240 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 12.16 W Creation date 16.12.2023 19:36:14 Subject to technical changes 2 Data sheet 1126.6 RK 240 GR Technical data Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 70 mm² Wire cross-section single core (rigid)/stranded, max. 240 mm² Wire cross-section stranded, min. 70 mm² Wire cross-section stranded, max. 240 mm² Wire cross-section stranded with wire-end ferrules,min. 70 mm² Wire cross-section stranded with wire-end ferrules,max. 185 mm² Wire cross-section AWG, min. 2/0 Wire cross-section AWG, max. 500 Kcmil Stripping length 38 mm Screw head Inner hex (Allen) Screw threading M 10 Tightening torque, min. 14 Nm Tightening torque, max. 20 Nm Wire cross-section single-core (rigid) / stranded, AWGmax. 500 Kcmil Wire cross-section single-core (rigid) / stranded, AWGmin. 2/0 Wire cross-section stranded, AWG max. 500 Kcmil Wire cross-section stranded, AWG min. 2/0 Wire cross-section stranded with wire-end ferrules, AWG min. 2/0 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7.5 and TS 32 Gauge plug acc. to EN 60 947-1 B16 Banded wire up to 20 x 12 mm Creation date 16.12.2023 19:36:14 Subject to technical changes 3 Data sheet 1126.6 RK 240 GR Technical data Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 19:36:14 No Subject to technical changes 4 Data sheet 1126.6 RK 240 GR Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 370 A CSA wire cross-section AWG, min. 2/0 CSA wire cross-section AWG, max. 500 Kcmil CSA stripping length 38 mm CSA File Number 042110_0_000 CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 370 A CSAus wire cross-section AWG, min. 2/0 CSAus wire cross-section AWG, max. 500 Kcmil CSAus stripping length 38 mm CSAus File Number 042110_0_000 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 1000 V KEMA rated current 415 A KEMA rated impulse voltage 12 kV KEMA wire cross-section single core (rigid), min. 50 mm² KEMA wire cross-section single-core (rigid), max. 240 mm² KEMA wire cross-section stranded, min. 70 mm² KEMA wire cross-section stranded, max. 240 mm² KEMA stripping length 38 mm KEMA torque, min. 14 Nm KEMA torque, max. 20 Nm Creation date 16.12.2023 19:36:14 Subject to technical changes 5 Data sheet 1126.6 RK 240 GR Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 370 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 370 A UL wire cross-section single-core (rigid) AWG, min. 2/0 UL wire cross-section single-core (rigid) AWG, max. 500 Kcmil UL wire cross-section stranded AWG, min. 2/0 UL wire cross-section stranded AWG, max. 500 Kcmil UL torque 142 Lb In UL wire material Cu UL factory wiring 1 UL File Number E95701 UL Recognized 1 German Lloyd approval DNV GL Certificate number TAE000014T DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 240 mm² DNV GL rated current 370 A DNV GL rated voltage 600 V DNV GL test standard IEC 60947-7-1:2002 Creation date 16.12.2023 19:36:14 Subject to technical changes 6 Data sheet 1126.6 RK 240 GR Media Creation date 16.12.2023 19:36:14 Subject to technical changes 7 Data sheet 1126.6 RK 240 GR Accessories Cover Cover, Length: 60 mm, Width: 25.5 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2808.0 AD 1/240/B YE 4044211055370 20 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Measurement pick-off terminal Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1125.2 MAG 150/240 BG 4044211080921 10 ST Insulated cross-connector External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 103.12 mm, Rated current: 380 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2770.2 AQI 3/240 YE 4044211055004 5 Creation date 16.12.2023 19:36:14 Subject to technical changes 8 Data sheet 1126.6 RK 240 GR Insulated cross-connector External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 66.28 mm, Rated current: 380 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2769.2 AQI 2/240 YE 4044211054991 5 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST ##INVERSE##CONTA-CONNECT Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1125.2 MAG 150/240 BG 4044211080921 10 ST Creation date 16.12.2023 19:36:14 Subject to technical changes 9
1126.6 价格&库存
很抱歉,暂时无法提供与“1126.6”相匹配的价格&库存,您可以联系我们找货
