1131.2
1131.2
    CONTA-CLIP
    TEST DISCONNECT TERMINAL
1131.2 数据手册
Data sheet 1131.2 PTK 10/LT/STB BG Test disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated crosssection: 10 mm², Width: 8 mm, Colour: Beige Business data Article number 1131.2 Article name PTK 10/LT/STB BG GTIN (EAN) 4044211019969 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 27.4 g Weight per piece (including packaging) 28.9 g Unit of weight G Customs number 85369010 Country of origin DE Product description Test disconnect terminal Colour Beige Creation date 15.12.2023 12:31:42 Subject to technical changes 1 Data sheet 1131.2 PTK 10/LT/STB BG Technical data Dimensions Length 72 mm Width 8 mm Height 45.5 mm Height TS 35/7.5 47 mm Height TS 32 51.5 mm Ratings Rated voltage 400 V Rated current 10 A Rated cross-section 10 mm² Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 0.32 W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 10 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 10 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 10 mm² Wire cross-section AWG, min. 8 Wire cross-section AWG, max. 22 Stripping length 12 mm Screw head Slotted Screw threading M4 Tightening torque, min. 1.2 Nm Tightening torque, max. 2 Nm Creation date 15.12.2023 12:31:42 Subject to technical changes 2 Data sheet 1131.2 PTK 10/LT/STB BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7.5 and TS 32 Gauge plug acc. to EN 60 947-1 A5 End plate required Number of test pick-off options 2 Built-in test socket available Version of lengthwise partition Sliding Test sockets 2 x 0,4 mm Ø Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 15.12.2023 12:31:42 Subject to technical changes 3 Data sheet 1131.2 PTK 10/LT/STB BG Approvals CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 45 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 8 CSA stripping length 12 mm CSA torque, max. 2 Nm CSA torque, min. 1.2 Nm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 45 A CSAus wire cross-section AWG, min. 22 CSAus wire cross-section AWG, max. 8 CSAus stripping length 12 mm CSAus torque, min. 1.2 Nm CSAus torque, max. 2 Nm Creation date 15.12.2023 12:31:42 Subject to technical changes 4 Data sheet 1131.2 PTK 10/LT/STB BG Media Creation date 15.12.2023 12:31:42 Subject to technical changes 5 Data sheet 1131.2 PTK 10/LT/STB BG Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2782.2 AP L/Q/D BG 4044211055110 20 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Short-circuit plug Short-circuit plug, Colour: Black Article number Article name GTIN (EAN) Packaging unit 2886.0 KSS 2-8 4044211056117 10 ST Test plug Test plug, Colour: Red Article number Article name GTIN (EAN) Packaging unit 2051.0 PS 4 4044211048570 20 ST Quick marking Creation date 15.12.2023 12:31:42 Subject to technical changes 6 Data sheet 1131.2 PTK 10/LT/STB BG Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1087.0 SDB 0,8x4,0 4044211014803 1 ST Insulation plate Insulation plate, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2003.2 TRS 1 BG 4044211048068 100 Cross-switch bridge Cross-switch bridge, No. of poles: 2, Mounting type: Can be screwed on, Width: 15.4 mm, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 2197.0 QVS 2 4044211050252 20 ST Cross-switch bridge, No. of poles: 4, Mounting type: Can be screwed on, Width: 31.6 mm, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 2199.0 QVS 4 4044211050276 20 ST Creation date 15.12.2023 12:31:42 Subject to technical changes 7 Data sheet 1131.2 PTK 10/LT/STB BG Cross-switch bridge Cross-switch bridge, No. of poles: 3, Mounting type: Can be screwed on, Width: 23.5 mm, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 2198.0 QVS 3 4044211050269 20 ST Insulated cross-connector Insulated cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 78.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2753.2 QI 10 YE 4044211054892 10 ST Insulated cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 28.8 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2752.2 QI 4 YE 4044211054885 20 ST Insulated cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 13.6 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2750.2 QI 2 YE 4044211054861 50 ST Insulated cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 21.7 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2751.2 QI 3 YE 4044211054878 50 ST Switch lock Creation date 15.12.2023 12:31:42 Subject to technical changes 8 Data sheet 1131.2 PTK 10/LT/STB BG Switch lock, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17368.3 PTK-SP OG 4044211185169 50 ST Creation date 15.12.2023 12:31:42 Subject to technical changes 9
1131.2 价格&库存
很抱歉,暂时无法提供与“1131.2”相匹配的价格&库存,您可以联系我们找货
  • 50+69.5009050+9.00161
