Data sheet
1134.2 PTK 10/DU BG
Test disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated crosssection: 10 mm², Width: 8 mm, Colour: Beige
Business data
Article number
1134.2
Article name
PTK 10/DU BG
GTIN (EAN)
4044211020293
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
21 g
Weight per piece (including packaging)
22.56 g
Unit of weight
G
Customs number
85369010
Country of origin
BG
Product description
Colour
Beige
Creation date 16.12.2023 19:35:42
Subject to technical changes
1
Data sheet
1134.2 PTK 10/DU BG
Technical data
Dimensions
Length
72 mm
Width
8 mm
Height
45.5 mm
Height TS 35/7.5
47 mm
Height TS 32
51.5 mm
Ratings
Rated voltage
400 V
Rated current
10 A
Rated cross-section
10 mm²
Rated impulse voltage
4 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
0.32 W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
2
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
10 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
10 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
10 mm²
Wire cross-section AWG, min.
8
Wire cross-section AWG, max.
22
Stripping length
12 mm
Screw head
Slotted
Screw threading
M4
Tightening torque, min.
1.2 Nm
Tightening torque, max.
2 Nm
2
Data sheet
1134.2 PTK 10/DU BG
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Gauge plug acc. to EN 60 947-1
A5
Number of cross-connection channels
2
End plate required
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
1134.2 PTK 10/DU BG
Approvals
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
600 V
CSA Usegroup C: rated current
45 A
CSA wire cross-section AWG, min.
22
CSA wire cross-section AWG, max.
8
CSA stripping length
12 mm
CSA torque, max.
2 Nm
CSA torque, min.
1.2 Nm
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup C: rated voltage
600 V
CSAus Usegroup C: rated current
45 A
CSAus wire cross-section AWG, min.
22
CSAus wire cross-section AWG, max.
8
CSAus stripping length
12 mm
CSAus torque, min.
1.2 Nm
CSAus torque, max.
2 Nm
4
Data sheet
1134.2 PTK 10/DU BG
Media
5
Data sheet
1134.2 PTK 10/DU BG
Accessories
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2782.2
AP L/Q/D BG
4044211055110
20 ST
End stop
End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2828.0
ES 35/K/ST BG
4044211055547
50
Short-circuit plug
Short-circuit plug, Colour: Black
Article number
Article name
GTIN (EAN)
Packaging
unit
2886.0
KSS 2-8
4044211056117
10 ST
Test plug
Test plug, Colour: Red
Article number
Article name
GTIN (EAN)
Packaging
unit
2051.0
PS 4
4044211048570
20 ST
Insulated cross-connector
6
Data sheet
1134.2 PTK 10/DU BG
Insulated cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width:
78.4 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2753.2
QI 10 YE
4044211054892
10 ST
Insulated cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width:
28.8 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2752.2
QI 4 YE
4044211054885
20 ST
Insulated cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width:
13.6 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2750.2
QI 2 YE
4044211054861
50 ST
Insulated cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width:
21.7 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2751.2
QI 3 YE
4044211054878
50 ST
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
9323.7
PMC SB 8/40 WH
4044211129231
400 ST
Screwdriver
7
Data sheet
1134.2 PTK 10/DU BG
Screwdriver with bare blade, Colour: Black-grey
Article number
Article name
GTIN (EAN)
Packaging
unit
1087.0
SDB 0,8x4,0
4044211014803
1 ST
Insulation plate
Insulation plate, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2003.2
TRS 1 BG
4044211048068
100
Connecting sleeve
Connecting sleeve, Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2238.0
VH 19
4044211050610
50 ST
Cross-switch bridge
Cross-switch bridge, No. of poles: 2, Mounting type: Can be screwed on, Width: 15.4 mm,
Colour: Orange
Article number
Article name
GTIN (EAN)
Packaging
unit
2197.0
QVS 2
4044211050252
20 ST
Cross-switch bridge, No. of poles: 4, Mounting type: Can be screwed on, Width: 31.6 mm,
Colour: Orange
Article number
Article name
GTIN (EAN)
Packaging
unit
2199.0
QVS 4
4044211050276
20 ST
8
Data sheet
1134.2 PTK 10/DU BG
Cross-switch bridge
Cross-switch bridge, No. of poles: 3, Mounting type: Can be screwed on, Width: 23.5 mm,
Colour: Orange
Article number
Article name
GTIN (EAN)
Packaging
unit
2198.0
QVS 3
4044211050269
20 ST
9
