11422.1
11422.1
    CONTA-CLIP
    P=5mm
    接线端子 间距:5.00mm 1x12P 自由悬挂
11422.1 数据手册
Data sheet 11422.1 PZB 3950/12/5,00 GN Female socket block, Tension-spring connection, No. of poles: 12, Width: 61.6 mm, Colour: Green Business data Article number 11422.1 Article name PZB 3950/12/5,00 GN GTIN (EAN) 4044211021221 Connector version Free connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 21.6 g Weight per piece (including packaging) 22.95 g Unit of weight G Customs number 85366930 Country of origin QU Colour Green Creation date 14.12.2023 19:23:59 Subject to technical changes 1 Data sheet 11422.1 PZB 3950/12/5,00 GN Technical data Dimensions Length 14.5 mm Width 61.6 mm Width left 4.1 mm Width right 2.5 mm Height 26.3 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 12 A Rated cross-section 2.5 mm² Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Tension-spring connection Angle of wire connection/contact 0°/180° (horizontal) Number of plug-in rows 1 No. of poles 12 Contact version Female connector Wire cross-section single-core (rigid) / stranded, min. 0.08 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.08 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.14 mm² Wire cross-section stranded with wire-end ferrules, max. 1.5 mm² Wire cross-section AWG, min. 28 Wire cross-section AWG, max. 12 Stripping length 8.5 mm Creation date 14.12.2023 19:23:59 Subject to technical changes 2 Data sheet 11422.1 PZB 3950/12/5,00 GN Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact spring Copper alloy Tension spring Stainless steel Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 10 Plug-in cycles acc. to standard 100 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 19:23:59 Subject to technical changes 3 Data sheet 11422.1 PZB 3950/12/5,00 GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 28 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 28 cUL wire cross-section stranded AWG, max. 12 cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 28 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 28 UL wire cross-section stranded AWG, max. 12 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 14.12.2023 19:23:59 Subject to technical changes 4 Data sheet 11422.1 PZB 3950/12/5,00 GN Approvals VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 4V VDE rated current 12 A VDE rated current wire cross-section rigid, min. 5A VDE rated current wire cross-section rigid, max. 12 A VDE rated current wire cross-section stranded, min. 5A VDE rated current wire cross-section stranded, max. 12 A VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 19:23:59 Subject to technical changes 5 Data sheet 11422.1 PZB 3950/12/5,00 GN Media Creation date 14.12.2023 19:23:59 Subject to technical changes 6 Data sheet 11422.1 PZB 3950/12/5,00 GN Accessories Creation date 14.12.2023 19:23:59 Subject to technical changes 7
11422.1
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
11422.1 价格&库存
很抱歉,暂时无法提供与“11422.1”相匹配的价格&库存,您可以联系我们找货
