11439.4
    CONTA-CLIP
    HEADER
11439.4 数据手册
Data sheet 11439.4 STL 130/6/5,00-V BK Male pin block, No. of poles: 6, Width: 30 mm, Colour: Black RAL: 9005 Business data Article number 11439.4 Article name STL 130/6/5,00-V BK GTIN (EAN) 4044211021436 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 0.8 g Weight per piece (including packaging) 1.22 g Unit of weight G Customs number 85366930 Country of origin TN Colour Black Creation date 16.12.2023 19:35:20 Subject to technical changes 1 Data sheet 11439.4 STL 130/6/5,00-V BK Technical data Dimensions Length 2.8 mm Length of the pin 3.5 mm Width 30 mm Width left 2.5 mm Width right 2.5 mm Height 9 mm Drill hole diameter 1.5 mm Diameter of connecting pin 1.3 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 7A Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 90° (vertically upwards) Number of plug-in rows 1 No. of poles 6 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Brass Creation date 16.12.2023 19:35:20 Subject to technical changes 2 Data sheet 11439.4 STL 130/6/5,00-V BK Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 16.12.2023 19:35:20 Subject to technical changes 3 Data sheet 11439.4 STL 130/6/5,00-V BK Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 10 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 10 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 7A VDE rated impulse voltage 4 kV VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:35:20 Subject to technical changes 4 Data sheet 11439.4 STL 130/6/5,00-V BK Media Creation date 16.12.2023 19:35:20 Subject to technical changes 5 Data sheet 11439.4 STL 130/6/5,00-V BK Accessories Creation date 16.12.2023 19:35:20 Subject to technical changes 6
11439.4 价格&库存
很抱歉,暂时无法提供与“11439.4”相匹配的价格&库存,您可以联系我们找货
