11497.4
11497.4
    CONTA-CLIP
    HEADER
11497.4 数据手册
Data sheet 11497.4 STL 140/7/5,00-H BK Male pin block, No. of poles: 7, Width: 35 mm, Colour: Black RAL: 9005 Business data Article number 11497.4 Article name STL 140/7/5,00-H BK GTIN (EAN) 4044211022136 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 1.61 g Weight per piece (including packaging) 1.81 g Unit of weight G Customs number 85366930 Country of origin QU Colour Black Creation date 16.12.2023 19:43:16 Subject to technical changes 1 Data sheet 11497.4 STL 140/7/5,00-H BK Technical data Dimensions Length 12.5 mm Length of the pin 3.4 mm Width 35 mm Width left 2.5 mm Width right 2.5 mm Height 5.4 mm Drill hole diameter 1.5 mm Diameter of connecting pin 1.3 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 7A Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 0°/180° (horizontal) Number of plug-in rows 1 No. of poles 7 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Brass Creation date 16.12.2023 19:43:16 Subject to technical changes 2 Data sheet 11497.4 STL 140/7/5,00-H BK Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 19:43:16 Subject to technical changes 3 Data sheet 11497.4 STL 140/7/5,00-H BK Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 7A VDE rated impulse voltage 4 kV VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:43:16 Subject to technical changes 4 Data sheet 11497.4 STL 140/7/5,00-H BK Media Creation date 16.12.2023 19:43:16 Subject to technical changes 5 Data sheet 11497.4 STL 140/7/5,00-H BK Accessories Creation date 16.12.2023 19:43:16 Subject to technical changes 6
11497.4
物料型号:11497.4 STL 140/7/5,00-H BK
器件简介:该产品是一个7针的公头插块,宽度35毫米,颜色为黑色。
引脚分配:7个插针,间距为5毫米。
参数特性: - 额定电压:250V - 额定电流:7A - 额定冲击电压:4kV - 过电压类别:III - 污染等级:3
功能详解: - 连接角度:PCB/接触 0°/180°(水平) - 插针排数:1 - 材料:聚酰胺6.6(绝缘体),黄铜(接触针) - 耐温:-30°C至105°C - 耐燃等级:UL 94 V-0
应用信息: - 存储温度:-40°C至105°C - 绝缘电阻:110^13欧姆·厘米 - 爬电电流耐压:CTI 600 - 灼热丝耐燃指数:GWFI 850 - 灼热丝点燃温度:GWIT 775°C
封装信息: - 包装单位:50个/箱 - 包装类型:纸箱 - 包装重量:单件1.61克(不含包装),1.81克(含包装) - 产品重量单位:克 - 原产国:QU(可能是代码)
11497.4 价格&库存
很抱歉,暂时无法提供与“11497.4”相匹配的价格&库存,您可以联系我们找货
  • 50+12.8361150+1.60968
