11578.1
    CONTA-CLIP
    插件,P=5mm
    HEADER
11578.1 数据手册
Data sheet 11578.1 STL 950/19/5,00-H GN Male pin block, No. of poles: 19, Width: 95 mm, Colour: Green Business data Article number 11578.1 Article name STL 950/19/5,00-H GN GTIN (EAN) 4044211023102 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 5.97 g Weight per piece (including packaging) 7.27 g Unit of weight G Customs number 85366930 Country of origin TN Colour Green Creation date 14.12.2023 19:13:19 Subject to technical changes 1 Data sheet 11578.1 STL 950/19/5,00-H GN Technical data Dimensions Length 12 mm Length of the pin 3.5 mm Width 95 mm Width left 2.5 mm Width right 2.5 mm Height 8.4 mm Drill hole diameter 1.4 mm Diameter of connecting pin 1 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 12 A Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 0°/180° (horizontal) Number of plug-in rows 1 No. of poles 19 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Copper alloy Creation date 14.12.2023 19:13:19 Subject to technical changes 2 Data sheet 11578.1 STL 950/19/5,00-H GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 19:13:19 Subject to technical changes 3 Data sheet 11578.1 STL 950/19/5,00-H GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 12 A VDE rated impulse voltage 4 kV VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 19:13:19 Subject to technical changes 4 Data sheet 11578.1 STL 950/19/5,00-H GN Media Creation date 14.12.2023 19:13:19 Subject to technical changes 5 Data sheet 11578.1 STL 950/19/5,00-H GN Accessories Creation date 14.12.2023 19:13:19 Subject to technical changes 6
11578.1
物料型号:11578.1 STL 950/19/5,00-H GN
器件简介:这是一个19极的公头插针块,宽度为95mm,颜色为绿色。
引脚分配:此器件共有19个插针,间距为5mm。
参数特性: - 额定电压:250V - 额定电流:12A - 额定脉冲电压:4kV - 污染等级:3 - 连接数据:PCB/接触角为0/180°(水平) - 插针材料:铜合金
功能详解: - 存储温度范围:-40°C至105°C - 绝缘电阻:110^13欧姆x厘米 - 爬电电流电阻:CTI600 - 灼热丝可燃性指数GWFI:GWFI 850 - GWFI后的余辉时间:30秒 - 灼热丝点燃温度GWIT:GWIT 775°C - GWIT暴露时间:5秒 - 插拔次数:根据标准100次 - 推荐的波峰焊接温度:265°C - 推荐的波峰焊接时间:最短3秒,最长4秒
应用信息:该插针块适用于需要高电压和电流的应用场景。
封装信息: - 绝缘外壳材料:聚酰胺6.6 - 阻燃等级:UL 94 V-0 - 工作温度范围:-30°C至105°C
11578.1 价格&库存
很抱歉,暂时无法提供与“11578.1”相匹配的价格&库存,您可以联系我们找货
