11593.1
11593.1
    CONTA-CLIP
    插件,P=5.08mm
    接线端子 1x11P 间距:5.08mm 排数:1 每排Pin数:11
11593.1 数据手册
Data sheet 11593.1 STL 950/11/5,08-H GN Male pin block, No. of poles: 11, Width: 55.88 mm, Colour: Green Business data Article number 11593.1 Article name STL 950/11/5,08-H GN GTIN (EAN) 4044211023294 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 3.4 g Weight per piece (including packaging) 4.64 g Unit of weight G Customs number 85366930 Country of origin TN Colour Green Creation date 14.12.2023 23:24:34 Subject to technical changes 1 Data sheet 11593.1 STL 950/11/5,08-H GN Technical data Dimensions Length 12 mm Length of the pin 3.5 mm Width 55.88 mm Width left 2.54 mm Width right 2.54 mm Height 8.4 mm Drill hole diameter 1.4 mm Diameter of connecting pin 1 mm Pitch 5.08 mm Ratings Rated voltage 250 V Rated current 12 A Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 0°/180° (horizontal) Number of plug-in rows 1 No. of poles 11 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Copper alloy Creation date 14.12.2023 23:24:34 Subject to technical changes 2 Data sheet 11593.1 STL 950/11/5,08-H GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 23:24:34 Subject to technical changes 3 Data sheet 11593.1 STL 950/11/5,08-H GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 12 A VDE rated impulse voltage 4 kV VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 23:24:34 Subject to technical changes 4 Data sheet 11593.1 STL 950/11/5,08-H GN Media Creation date 14.12.2023 23:24:34 Subject to technical changes 5 Data sheet 11593.1 STL 950/11/5,08-H GN Accessories Creation date 14.12.2023 23:24:34 Subject to technical changes 6
11593.1
物料型号为11593.1 STL 950/11/5,08-H GN,这是一个公头针座,具有11个针脚,宽度为55.88毫米,颜色为绿色。
器件简介:这是一个用于连接的附件插件,具有额定电压250V、额定电流12A、额定脉冲电压4kV,适用于污染等级3。
引脚分配:针脚数量为11,间距为5.08毫米。
参数特性:包括尺寸(长度12毫米、针长3.5毫米、宽度55.88毫米、左侧宽度2.54毫米、右侧宽度2.54毫米、高度8.4毫米)、钻孔直径1.4毫米、连接针直径1毫米、绝缘材料为聚酰胺6.6、UL94阻燃等级V-0、工作温度范围-30°C至105°C、接触针材料为铜合金。
功能详解:可应用于PCB/接触0°/180°(水平)、1排插入、11个针脚、材料包括聚酰胺6.6绝缘体、铜合金接触针,具有较高的绝缘电阻和爬电电流电阻。
应用信息:适用于符合REACH法规和RoHS指令的产品,有100次的插拔循环,推荐的波峰焊接温度为265°C,持续时间建议在3至4秒之间。
封装信息:包装单位为50个/箱,包装类型为纸箱,重量为3.4克(不含包装)、4.64克(含包装),原产国为TN。
此外,该产品还通过了cUL、UL和VDE的认证。
11593.1 价格&库存
很抱歉,暂时无法提供与“11593.1”相匹配的价格&库存,您可以联系我们找货
