11935.1
11935.1
    CONTA-CLIP
    插件,P=3.81mm
    接线端子 间距:3.81mm 1x7P 直插
11935.1 数据手册
Data sheet 11935.1 STL 1550/7/3,81-H-G GN Male pin block, No. of poles: 7, Width: 28.06 mm, Colour: Green Business data Article number 11935.1 Article name STL 1550/7/3,81-H-G GN GTIN (EAN) 4044211026950 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 1.4 g Weight per piece (including packaging) 1.87 g Unit of weight G Customs number 85366930 Country of origin TN Colour Green Creation date 16.12.2023 19:46:37 Subject to technical changes 1 Data sheet 11935.1 STL 1550/7/3,81-H-G GN Technical data Dimensions Length 9.2 mm Length of the pin 3.5 mm Width 28.06 mm Width left 2.6 mm Width right 2.6 mm Height 7 mm Drill hole diameter 1.2 mm Diameter of connecting pin 0.8 mm Pitch 3.81 mm Ratings Rated voltage 160 V Rated current 10 A Rated impulse voltage 2.5 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 0°/180° (horizontal) Number of plug-in rows 1 No. of poles 7 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Copper alloy Creation date 16.12.2023 19:46:37 Subject to technical changes 2 Data sheet 11935.1 STL 1550/7/3,81-H-G GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 19:46:37 Subject to technical changes 3 Data sheet 11935.1 STL 1550/7/3,81-H-G GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 160 V VDE rated current 10 A VDE rated impulse voltage 2.5 kV VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:46:37 Subject to technical changes 4 Data sheet 11935.1 STL 1550/7/3,81-H-G GN Media Creation date 16.12.2023 19:46:37 Subject to technical changes 5 Data sheet 11935.1 STL 1550/7/3,81-H-G GN Accessories Creation date 16.12.2023 19:46:37 Subject to technical changes 6
11935.1 价格&库存
很抱歉,暂时无法提供与“11935.1”相匹配的价格&库存,您可以联系我们找货
