11936.1
11936.1
    CONTA-CLIP
    插件,P=3.81mm
    接线端子 间距:3.81mm 1x8P 直插
11936.1 数据手册
Data sheet 11936.1 STL 1550/8/3,81-H-G GN Male pin block, No. of poles: 8, Width: 31.87 mm, Colour: Green Business data Article number 11936.1 Article name STL 1550/8/3,81-H-G GN GTIN (EAN) 4044211026967 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 1.6 g Weight per piece (including packaging) 2.07 g Unit of weight G Customs number 85366930 Country of origin TN Colour Green Creation date 14.12.2023 20:20:30 Subject to technical changes 1 Data sheet 11936.1 STL 1550/8/3,81-H-G GN Technical data Dimensions Length 9.2 mm Length of the pin 3.5 mm Width 31.87 mm Width left 2.6 mm Width right 2.6 mm Height 7 mm Drill hole diameter 1.2 mm Diameter of connecting pin 0.8 mm Pitch 3.81 mm Ratings Rated voltage 160 V Rated current 10 A Rated impulse voltage 2.5 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 0°/180° (horizontal) Number of plug-in rows 1 No. of poles 8 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Copper alloy Creation date 14.12.2023 20:20:30 Subject to technical changes 2 Data sheet 11936.1 STL 1550/8/3,81-H-G GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 20:20:30 Subject to technical changes 3 Data sheet 11936.1 STL 1550/8/3,81-H-G GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 160 V VDE rated current 10 A VDE rated impulse voltage 2.5 kV VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 20:20:30 Subject to technical changes 4 Data sheet 11936.1 STL 1550/8/3,81-H-G GN Media Creation date 14.12.2023 20:20:30 Subject to technical changes 5 Data sheet 11936.1 STL 1550/8/3,81-H-G GN Accessories Creation date 14.12.2023 20:20:30 Subject to technical changes 6
11936.1
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一种红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,常用于遥控器等设备。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V至1.8V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817的主要功能是发射红外光,用于无线通信。
6. 应用信息:广泛应用于遥控器、红外通信等领域。
7. 封装信息:EL817采用黑色环氧树脂封装,尺寸为3.4mm x 1.6mm。
11936.1 价格&库存
很抱歉,暂时无法提供与“11936.1”相匹配的价格&库存,您可以联系我们找货
