11988.1
11988.1
    CONTA-CLIP
    插件,P=3.81mm
    接线端子 间距:3.81mm 1x7P 直插
11988.1 数据手册
Data sheet 11988.1 STL 1590/7/3,81-G GN Male pin block, No. of poles: 7, Width: 28.06 mm, Colour: Green Business data Article number 11988.1 Article name STL 1590/7/3,81-G GN GTIN (EAN) 4044211027513 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 2g Weight per piece (including packaging) 2.9 g Unit of weight G Customs number 85366930 Country of origin TN Colour Green Creation date 16.12.2023 19:46:23 Subject to technical changes 1 Data sheet 11988.1 STL 1590/7/3,81-G GN Technical data Dimensions Length 13.1 mm Length of the pin 3.4 mm Width 28.06 mm Width left 2.6 mm Width right 2.6 mm Height 11 mm Drill hole diameter 1.2 mm Diameter of connecting pin 0.8 mm Pitch 3.81 mm Ratings Rated voltage 160 V Rated current 10 A Rated impulse voltage 2.5 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 45°/135° (slanted upwards) Number of plug-in rows 1 No. of poles 7 Materials Insulation housing Polybutylene terephthalate Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Copper alloy Creation date 16.12.2023 19:46:23 Subject to technical changes 2 Data sheet 11988.1 STL 1590/7/3,81-G GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 175 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 19:46:23 Subject to technical changes 3 Data sheet 11988.1 STL 1590/7/3,81-G GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 160 V VDE rated current 10 A VDE rated impulse voltage 2.5 kV VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:46:23 Subject to technical changes 4 Data sheet 11988.1 STL 1590/7/3,81-G GN Media Creation date 16.12.2023 19:46:23 Subject to technical changes 5 Data sheet 11988.1 STL 1590/7/3,81-G GN Accessories Creation date 16.12.2023 19:46:23 Subject to technical changes 6
11988.1
物料型号:11988.1 STL 1590/7/3,81-G GN
器件简介: - 这是一个7针的公头插孔,宽度为28.06毫米,颜色为绿色。 - 产品编号为11988.1,GTIN(EAN)为4044211027513。 - 包装单位为50,单位为PC(件),包装类型为纸箱。
引脚分配: - 引脚数量:7 - 引脚间距:3.81毫米 - 引脚长度:3.4毫米 - 连接销直径:0.8毫米
参数特性: - 额定电压:160V - 额定电流:10A - 额定脉冲电压:2.5kV - 污染等级:3 - 工作温度范围:-30°C 至 105°C - 存储温度范围:-40°C 至 105°C - 绝缘电阻:110^13欧姆 x 厘米 - 爬电电流电阻:CTI 175 - 灼热丝可燃性指数(GWFI):GWFI 850 - 灼热丝点火温度(GWIT):GWIT 775°C
功能详解: - 该插孔设计用于PCB上的45°/135°斜向上接触。 - 插拔次数:100次(根据标准) - 推荐波峰焊接温度:265°C - 推荐波峰焊接时间:3至4秒
应用信息: - 该产品符合REACH和RoHS标准。
封装信息: - 绝缘体材料:聚对苯二甲酸丁二醇酯(Polybutylene terephthalate) - 阻燃等级:UL 94 V-0
认证信息: - cUL认证:CSA 22.2 No.158 - UL认证:UL1059 - VDE认证:DIN EN61984
11988.1 价格&库存
很抱歉,暂时无法提供与“11988.1”相匹配的价格&库存,您可以联系我们找货
    • 1+16.22160
    • 200+6.27480
    • 500+6.05880
    • 1000+5.95080
