Data sheet
12030.0 PZK 3191/22/2,50 LG
PCB terminal, Tension-spring connection, No. of poles: 22, Width: 57 mm, Colour: Pebble grey
Business data
Article number
12030.0
Article name
PZK 3191/22/2,50 LG
GTIN (EAN)
4044211028008
Packaging unit
50
Quantity unit
PC
Packaging type
Carton
Type of banding
Without
Weight per piece (not including packaging)
6.9 g
Weight per piece (including packaging)
7.8 g
Unit of weight
G
Customs number
85369010
Country of origin
QU
Colour
Pebble grey
Creation date 16.12.2023 19:45:54
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
12.2 mm
Length of the pin
4 mm
Width
57 mm
Width left
2.7 mm
Width right
1.8 mm
Height
11.6 mm
Drill hole diameter
1.1 mm
Diameter of connecting pin
0.8 mm
Pitch
2.5 mm
Ratings
Rated voltage
130 V
Rated current
9A
Rated cross-section
0.5 mm²
Rated impulse voltage
1.25 kV
Overvoltage category
III
Contamination degree
3
Connection data
Connection principle
Connection type of PCB
Solder connection
Type of attachment to circuit board
Connecting contact
Angle of PCB/wire connection
45°/135° (slanted upwards)
No. of poles
22
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.08 mm²
Wire cross-section single core (rigid)/stranded, max.
1 mm²
Wire cross-section stranded, min.
0.14 mm²
Wire cross-section stranded, max.
0.5 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.14 mm²
max.
0.14 mm²
Wire cross-section AWG, min.
28
Wire cross-section AWG, max.
Stripping length
5 mm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-30 °C
Working temperature, max.
105 °C
Tension spring
Stainless steel
Soldering lug
Copper alloy
Further technical data
Storage temperature, min.
-40 °C
Storage temperature, max.
105 °C
Insulation resistance
1*10^13 Ohm x cm
Creepage-current resistance
CTI 600
Glow wire flammability index GWFI
GWFI 850
GWFI after-glow time
30 Sek.
Glow wire ignition temperature GWIT
GWIT 775 °C
GWIT exposure time
5 Sek.
Connection cycles, in compliance with standard
10
Recommended wave soldering temperature
265 °C
Recommended wave soldering duration, min.
3 Sek.
Recommended wave soldering duration, max.
4 Sek.
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
Approvals
cUL Recognized
cUL approval
CSA 22.2 No.158
cUL Usegroup B: rated voltage
150 V
cUL Usegroup B: rated current
4A
cUL wire cross-section single-core (rigid) AWG, min.
28
cUL wire cross-section single-core (rigid) AWG, max. 20
cUL wire cross-section stranded AWG, min.
28
cUL wire cross-section stranded AWG, max.
cUL wire material
Cu
cUL Recognized
1
UL Recognized
UL approval
UL 1059
150 V
4A
28
28
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
VDE approval
VDE approval
DIN EN 60998
VDE approval granted
yes
VDE rated voltage
130 V
VDE rated current
9A
VDE rated current wire cross-section rigid, max.
9A
VDE rated impulse voltage
1.25 kV
VDE wire cross-section rigid, min.
0.2 mm²
VDE wire cross-section rigid, max.
0.5 mm²
VDE overvoltage category
III
VDE contamination degree
3
4
Data sheet
Media
5
Data sheet
Accessories
6
很抱歉,暂时无法提供与“12030.0”相匹配的价格&库存,您可以联系我们找货
