1211.4
1211.4
    CONTA-CLIP
    FEED-THROUGH TERMINAL
1211.4 数据手册
Data sheet 1211.4 RK 2,5-4/ZRL BK Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated crosssection: 4 mm², Width: 6 mm, Colour: Black RAL: 9005 Business data Article number 1211.4 Article name RK 2,5-4/ZRL BK GTIN (EAN) 4044211028596 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 13.2 g Weight per piece (including packaging) 13.97 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 1211.2 Product description Feed-through terminal Creation date 16.12.2023 19:56:19 Subject to technical changes 1 Data sheet 1211.4 RK 2,5-4/ZRL BK Technical data Dimensions Length 67 mm Width 6 mm Height TS 35/7.5 47 mm Height TS 32 51.5 mm Ratings Rated voltage 500 V Rated current 24 A Rated cross-section 4 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 0.77 W Connection data Connection principle Screw connection Connection position Lateral Connections 4 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 9 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 16.12.2023 19:56:19 Subject to technical changes 2 Data sheet 1211.4 RK 2,5-4/ZRL BK Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7.5 and TS 32 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 1 End plate required Number of test pick-off options 1 Environmental Product Compliance REACH Conform Yes REACH Candidate Substance Note No Creation date 16.12.2023 19:56:19 Subject to technical changes 3 Data sheet 1211.4 RK 2,5-4/ZRL BK Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 600 V cUL Usegroup B: rated current 30 A cUL Usegroup C: rated voltage 600 V cUL Usegroup C: rated current 30 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 10 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 10 cUL torque 7 Nm cUL wire material Cu cUL File Number E95701 cUL Recognized 1 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 800 V KEMA rated current 32 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 6 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 6 mm² KEMA torque, min. 0.5 Nm KEMA torque, max. 1 Nm Creation date 16.12.2023 19:56:19 Subject to technical changes 4 Data sheet 1211.4 RK 2,5-4/ZRL BK Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 30 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 30 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 10 UL torque 7 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL File Number E95701 UL Recognized 1 Creation date 16.12.2023 19:56:19 Subject to technical changes 5 Data sheet 1211.4 RK 2,5-4/ZRL BK Media Creation date 16.12.2023 19:56:19 Subject to technical changes 6 Data sheet 1211.4 RK 2,5-4/ZRL BK Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2575.2 AP 2,5/RL BG 4044211053680 50 End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Cross-connector Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 17 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2020.0 Q3 4044211048235 50 ST Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 10.9 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2019.0 Q2 4044211048228 50 ST Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 23.1 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2021.0 Q4 4044211048242 20 ST Creation date 16.12.2023 19:56:19 Subject to technical changes 7 Data sheet 1211.4 RK 2,5-4/ZRL BK Cross-connector Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 59.7 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2022.0 Q 10 4044211048259 10 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Insulation plate Insulation plate, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2003.2 TRS 1 BG 4044211048068 100 Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Creation date 16.12.2023 19:56:19 Subject to technical changes 8 Data sheet 1211.4 RK 2,5-4/ZRL BK Test adapters Test adapter, Length: 37.3 mm, Pitch size: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2813.0 TA 6/1/ST 4044211055400 10 ST Creation date 16.12.2023 19:56:19 Subject to technical changes 9
1211.4 价格&库存
很抱歉,暂时无法提供与“1211.4”相匹配的价格&库存,您可以联系我们找货
