Data sheet
1211.7 RK 2,5-4/ZRL WH
Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated crosssection: 4 mm², Width: 6 mm, Colour: White
RAL: 9010
Business data
Article number
1211.7
Article name
RK 2,5-4/ZRL WH
GTIN (EAN)
4044211028640
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
13.2 g
Weight per piece (including packaging)
13.97 g
Unit of weight
G
Customs number
85369010
Country of origin
CZ
Prio-Article
1211.2
Product description
Creation date 16.12.2023 19:57:42
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
67 mm
Width
6 mm
Height TS 35/7.5
47 mm
Height TS 32
51.5 mm
Ratings
Rated voltage
500 V
Rated current
24 A
Rated cross-section
4 mm²
Rated impulse voltage
6 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
0.77 W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
4
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
2.5 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
12
Stripping length
9 mm
Screw head
Slotted
Screw threading
M3
Tightening torque, min.
0.5 Nm
Tightening torque, max.
1 Nm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Gauge plug acc. to EN 60 947-1
A4
Number of cross-connection channels
1
End plate required
Number of test pick-off options
1
Environmental Product Compliance
REACH Candidate Substance Note
No
3
Data sheet
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
cUL Recognized
cUL approval
C22.2 No 158
cUL Usegroup B: rated voltage
600 V
cUL Usegroup B: rated current
30 A
cUL Usegroup C: rated voltage
600 V
cUL Usegroup C: rated current
30 A
cUL wire cross-section single-core (rigid) AWG, min.
22
cUL wire cross-section single-core (rigid) AWG, max. 10
cUL wire cross-section stranded AWG, min.
22
cUL wire cross-section stranded AWG, max.
10
cUL torque
7 Nm
cUL wire material
Cu
cUL File Number
E95701
cUL Recognized
1
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
800 V
KEMA rated current
32 A
KEMA rated impulse voltage
6 kV
KEMA wire cross-section single core (rigid), min.
0.2 mm²
KEMA wire cross-section single-core (rigid), max.
6 mm²
KEMA wire cross-section stranded, min.
0.2 mm²
KEMA wire cross-section stranded, max.
6 mm²
KEMA torque, min.
0.5 Nm
KEMA torque, max.
1 Nm
4
Data sheet
Approvals
UL Recognized
UL approval
UL 1059
600 V
30 A
600 V
30 A
22
10
22
10
UL torque
7 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL File Number
E95701
UL Recognized
1
5
Data sheet
Media
6
Data sheet
Accessories
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2575.2
AP 2,5/RL BG
4044211053680
50
End stop
End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2828.0
ES 35/K/ST BG
4044211055547
50
Cross-connector
Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 17 mm,
Rated cross-section: 4 mm², Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2020.0
Q3
4044211048235
50 ST
Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 10.9 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2019.0
Q2
4044211048228
50 ST
Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 23.1 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2021.0
Q4
4044211048242
20 ST
7
Data sheet
Cross-connector
Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 59.7 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2022.0
Q 10
4044211048259
10 ST
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4702.7
PMC SB 6/50 WH
4044211089986
500 ST
Insulation plate
Insulation plate, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2003.2
TRS 1 BG
4044211048068
100
Screwdriver
Screwdriver with bare blade, Colour: Black-grey
Article number
Article name
GTIN (EAN)
Packaging
unit
1086.0
SDB 0,6x3,5
4044211014797
1 ST
8
Data sheet
Test adapters
Test adapter, Length: 37.3 mm, Pitch size: 6 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2813.0
TA 6/1/ST
4044211055400
10 ST
9
