12128.3
12128.3
    CONTA-CLIP
    插件
    接线端子
12128.3 数据手册
Data sheet 12128.3 PZK 3191/24/2,54 OG PCB terminal, Tension-spring connection, No. of poles: 24, Width: 62.96 mm, Colour: Orange Business data Article number 12128.3 Article name PZK 3191/24/2,54 OG GTIN (EAN) 4044211028794 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 7.6 g Weight per piece (including packaging) 8.52 g Unit of weight G Customs number 85369010 Country of origin TN Colour Orange Creation date 14.12.2023 18:33:39 Subject to technical changes 1 Data sheet 12128.3 PZK 3191/24/2,54 OG Technical data Dimensions Length 12.2 mm Length of the pin 4 mm Width 62.96 mm Width left 2.7 mm Width right 1.84 mm Height 11.6 mm Drill hole diameter 1.1 mm Diameter of connecting pin 0.8 mm Pitch 2.54 mm Ratings Rated voltage 130 V Rated current 9A Rated cross-section 0.5 mm² Rated impulse voltage 1.25 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Tension-spring connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 45°/135° (slanted upwards) No. of poles 24 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.08 mm² Wire cross-section single core (rigid)/stranded, max. 1 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 0.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.14 mm² Wire cross-section stranded with wire-end ferrules, max. 0.14 mm² Wire cross-section AWG, min. 28 Wire cross-section AWG, max. 20 Stripping length 5 mm Creation date 14.12.2023 18:33:39 Subject to technical changes 2 Data sheet 12128.3 PZK 3191/24/2,54 OG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Tension spring Stainless steel Soldering lug Copper alloy Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 10 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 18:33:39 Subject to technical changes 3 Data sheet 12128.3 PZK 3191/24/2,54 OG Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 150 V cUL Usegroup B: rated current 4A cUL wire cross-section single-core (rigid) AWG, min. 28 cUL wire cross-section single-core (rigid) AWG, max. 20 cUL wire cross-section stranded AWG, min. 28 cUL wire cross-section stranded AWG, max. 20 cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 150 V UL Usegroup B: rated current 4A UL wire cross-section single-core (rigid) AWG, min. 28 UL wire cross-section single-core (rigid) AWG, max. 20 UL wire cross-section stranded AWG, min. 28 UL wire cross-section stranded AWG, max. 20 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 130 V VDE rated current 9A VDE rated current wire cross-section rigid, max. 9A VDE rated impulse voltage 1.25 kV VDE wire cross-section rigid, min. 0.2 mm² VDE wire cross-section rigid, max. 0.5 mm² VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 18:33:39 Subject to technical changes 4 Data sheet 12128.3 PZK 3191/24/2,54 OG Media Creation date 14.12.2023 18:33:39 Subject to technical changes 5 Data sheet 12128.3 PZK 3191/24/2,54 OG Accessories Creation date 14.12.2023 18:33:39 Subject to technical changes 6
12128.3 价格&库存
很抱歉,暂时无法提供与“12128.3”相匹配的价格&库存,您可以联系我们找货
