1215.5
    CONTA-CLIP
    NEUTRAL CONDUCTOR DISCONNECT TER
1215.5 数据手册
Data sheet 1215.5 NT 6-10 | 10x3 BU Neutral-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 1215.5 Article name NT 6-10 | 10x3 BU GTIN (EAN) 4044211028862 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 16.8 g Weight per piece (including packaging) 18.04 g Unit of weight G Customs number 85369010 Country of origin CZ Product description Neutral disconnect terminal Colour Blue Creation date 17.12.2023 17:06:04 Subject to technical changes 1 Data sheet 1215.5 NT 6-10 | 10x3 BU Technical data Dimensions Length 48 mm Width 8 mm Height TS 35/7.5 47 mm Height TS 32 51.5 mm Ratings Rated voltage 400 V Rated current 57 A Rated cross-section 10 mm² Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.82 W Connection data Connection principle Screw connection Connection position Lateral Connections 1 Special connection Busbar 10 x 3 mm Number of terminals per level 1 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 10 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 10 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 10 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 10 Stripping length 12 mm Screw head Slotted Screw threading M4 Tightening torque, min. 1.2 Nm Tightening torque, max. 2 Nm Creation date 17.12.2023 17:06:04 Subject to technical changes 2 Data sheet 1215.5 NT 6-10 | 10x3 BU Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7.5 and TS 32 Gauge plug acc. to EN 60 947-1 A5 End plate required Version of lengthwise partition Sliding Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 17:06:04 Subject to technical changes 3 Data sheet 1215.5 NT 6-10 | 10x3 BU Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 400 V KEMA rated current 57 A KEMA rated impulse voltage 4 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 10 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 10 mm² KEMA torque, min. 1.2 Nm KEMA torque, max. 2 Nm KEMA torque busbar, min. 0.5 Nm KEMA torque busbar, max. 1 Nm Creation date 17.12.2023 17:06:04 Subject to technical changes 4 Data sheet 1215.5 NT 6-10 | 10x3 BU Media Creation date 17.12.2023 17:06:04 Subject to technical changes 5 Data sheet 1215.5 NT 6-10 | 10x3 BU Accessories End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Fixing plate Plate for busbar, Colour: Blue Article number Article name GTIN (EAN) Packaging unit 2576.5 HP 10x3 BU 4044211053703 20 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Neutral busbar Busbar, Material: Brass, Colour: natural Article number Article name GTIN (EAN) Packaging unit 2128.0 Ssch 10x3 MS 4044211049478 1M Busbar, Material: Copper, Colour: natural Article number Article name GTIN (EAN) Packaging unit 2129.0 Ssch 10x3 CU 4044211049485 1M Creation date 17.12.2023 17:06:04 Subject to technical changes 6 Data sheet 1215.5 NT 6-10 | 10x3 BU Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1087.0 SDB 0,8x4,0 4044211014803 1 ST Creation date 17.12.2023 17:06:04 Subject to technical changes 7
1215.5 价格&库存
很抱歉,暂时无法提供与“1215.5”相匹配的价格&库存,您可以联系我们找货
  • 50+33.6971550+4.21474
