12356.1
12356.1
    CONTA-CLIP
    插件,P=5mm
    接线端子 1x20P 5mm 直插 排数:单排 每排Pin数:20
12356.1 数据手册
Data sheet 12356.1 PK 350/20/5,00-V GN PCB terminal, Screw connection, No. of poles: 20, Width: 100.6 mm, Colour: Green Business data Article number 12356.1 Article name PK 350/20/5,00-V GN GTIN (EAN) 4044211030261 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 21.4 g Weight per piece (including packaging) 23 g Unit of weight G Customs number 85369010 Country of origin QU Colour Green Creation date 17.12.2023 17:09:00 Subject to technical changes 1 Data sheet 12356.1 PK 350/20/5,00-V GN Technical data Dimensions Length 9 mm Length of the pin 3.5 mm Width 100.6 mm Width left 3.1 mm Width right 2.5 mm Height 13.5 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 17.5 A Rated cross-section 1.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 17.12.2023 17:09:00 Subject to technical changes 2 Data sheet 12356.1 PK 350/20/5,00-V GN Technical data Connection data Connection principle Screw connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) No. of poles 20 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.14 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 1.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 6 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Soldering lug Brass Creation date 17.12.2023 17:09:00 Subject to technical changes 3 Data sheet 12356.1 PK 350/20/5,00-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 17.12.2023 17:09:00 Subject to technical changes 4 Data sheet 12356.1 PK 350/20/5,00-V GN Approvals cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 16 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 16 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 16 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.5 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 16 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 16 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 16 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 12 UL torque 4.43 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 17.12.2023 17:09:00 Subject to technical changes 5 Data sheet 12356.1 PK 350/20/5,00-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 17.5 A VDE rated current wire cross-section rigid, max. 17.5 A VDE rated current wire cross-section stranded, max. 17.5 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 17.12.2023 17:09:00 Subject to technical changes 6 Data sheet 12356.1 PK 350/20/5,00-V GN Media Creation date 17.12.2023 17:09:00 Subject to technical changes 7 Data sheet 12356.1 PK 350/20/5,00-V GN Accessories Creation date 17.12.2023 17:09:00 Subject to technical changes 8
12356.1 价格&库存
很抱歉,暂时无法提供与“12356.1”相匹配的价格&库存,您可以联系我们找货
