12383.1
12383.1
    CONTA-CLIP
    插件,P=5mm
    接线端子 1x23P 5mm 直插 排数:单排 每排Pin数:23
12383.1 数据手册
Data sheet 12383.1 PK 100/23/5,00-H GN PCB terminal, Wire protection, No. of poles: 23, Width: 115.7 mm, Colour: Green Business data Article number 12383.1 Article name PK 100/23/5,00-H GN GTIN (EAN) 4044211030667 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 25.8 g Weight per piece (including packaging) 27.6 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 12383.1 Creation date 16.12.2023 17:45:53 Subject to technical changes 1 Data sheet 12383.1 PK 100/23/5,00-H GN Technical data Dimensions Length 12.5 mm Length of the pin 3.8 mm Width 115.7 mm Width left 3.2 mm Width right 2.5 mm Height 9 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 17:45:53 Subject to technical changes 2 Data sheet 12383.1 PK 100/23/5,00-H GN Technical data Connection data Connection principle Wire protection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 90° (vertically upwards) No. of poles 23 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 6 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Wire protection Stainless steel Creation date 16.12.2023 17:45:53 Subject to technical changes 3 Data sheet 12383.1 PK 100/23/5,00-H GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 17:45:53 Subject to technical changes 4 Data sheet 12383.1 PK 100/23/5,00-H GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 12 cUL wire cross-section stranded AWG, max. 22 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 12 UL wire cross-section stranded AWG, max. 22 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 17:45:53 Subject to technical changes 5 Data sheet 12383.1 PK 100/23/5,00-H GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 17:45:53 Subject to technical changes 6 Data sheet 12383.1 PK 100/23/5,00-H GN Media Creation date 16.12.2023 17:45:53 Subject to technical changes 7 Data sheet 12383.1 PK 100/23/5,00-H GN Accessories Creation date 16.12.2023 17:45:53 Subject to technical changes 8
12383.1 价格&库存
很抱歉,暂时无法提供与“12383.1”相匹配的价格&库存,您可以联系我们找货
    • 1+42.85440
    • 200+16.58880
    • 500+16.00560
    • 1000+15.71400
