12420.1
12420.1
    CONTA-CLIP
    PCB TERMINAL
12420.1 数据手册
Data sheet 12420.1 PK 120/24/5,08-V GN PCB terminal, Wire protection, No. of poles: 24, Width: 122.62 mm, Colour: Green Business data Article number 12420.1 Article name PK 120/24/5,08-V GN GTIN (EAN) 4044211031435 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 26.3 g Weight per piece (including packaging) 28.2 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 12420.1 Creation date 17.12.2023 17:10:27 Subject to technical changes 1 Data sheet 12420.1 PK 120/24/5,08-V GN Technical data Dimensions Length 9 mm Length of the pin 4 mm Width 122.62 mm Width left 3.24 mm Width right 2.54 mm Height 13 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 5.08 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 17.12.2023 17:10:27 Subject to technical changes 2 Data sheet 12420.1 PK 120/24/5,08-V GN Technical data Connection data Connection principle Wire protection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) No. of poles 24 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 7 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Wire protection Stainless steel Creation date 17.12.2023 17:10:27 Subject to technical changes 3 Data sheet 12420.1 PK 120/24/5,08-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 260 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 17.12.2023 17:10:27 Subject to technical changes 4 Data sheet 12420.1 PK 120/24/5,08-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 12 cUL wire cross-section stranded AWG, max. 22 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 12 UL wire cross-section stranded AWG, max. 22 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 17.12.2023 17:10:27 Subject to technical changes 5 Data sheet 12420.1 PK 120/24/5,08-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 17.12.2023 17:10:27 Subject to technical changes 6 Data sheet 12420.1 PK 120/24/5,08-V GN Media Creation date 17.12.2023 17:10:27 Subject to technical changes 7 Data sheet 12420.1 PK 120/24/5,08-V GN Accessories Creation date 17.12.2023 17:10:27 Subject to technical changes 8
12420.1
物料型号: - 文章编号:12420.1 - 文章名称:PK120/24/5,08-V GN
器件简介: - 这是一种PCB端子,具有24个极,宽度为122.62毫米,颜色为绿色,用于导线保护。
引脚分配: - 长度:9毫米 - 引脚长度:4毫米 - 宽度:122.62毫米 - 左侧宽度:3.24毫米 - 右侧宽度:2.54毫米 - 高度:13毫米 - 钻孔直径:1.3毫米 - 连接销直径:1毫米 - 间距:5.08毫米
参数特性: - 额定电压:250V - 额定电流:24A - 额定截面积:2.5 mm² - 额定脉冲电压:2kV - 污染等级:3
功能详解: - 连接原理:导线保护 - PCB连接类型:焊接 - 连接到电路板的类型:连接接触 - PCB/导线连接角度:0/180°(水平) - 极数:24 - 层数:1 - 单芯线截面积(刚性)/绞合,最小:0.2 mm² - 单芯线截面积(刚性)/绞合,最大:2.5mm² - 绞合线截面积,最小:0.2 mm² - 绞合线截面积,最大:2.5mm² - 带端子的绞合线截面积,最小:0.2mm² - 带端子的绞合线截面积,最大:2.5mm² - 绞合线AWG截面积,最小:22 - 绞合线AWG截面积,最大:12 - 剥离长度:7毫米 - 螺钉螺纹:M3 - 扭矩:0.5Nm
应用信息: - 绝缘外壳材料:聚酰胺6.6 - 阻燃等级:UL 94 V-0 - 工作温度范围:-30°C 至 105°C - 夹紧元件:黄铜 - 螺钉:钢 - 导线保护:不锈钢
封装信息: - 存储温度范围:-40°C 至 105°C - 绝缘电阻:110^13欧姆 x 厘米 - 爬电电流电阻:CTI600 - 灼热丝可燃性指数(GWFI):GWFI 850 - GWFI后余辉时间:30秒 - 灼热丝点燃温度(GWIT):GWIT 775°C - GWIT暴露时间:5秒 - 连接周期,符合标准:5 - 推荐的波峰焊接温度:260°C - 推荐的波峰焊接持续时间,最小:3秒 - 推荐的波峰焊接持续时间,最大:4秒
认证信息: - cUL认可:CSA 22.2 No.158 - cUL使用组B:额定电压300V,额定电流20A - cUL使用组D:额定电压300V,额定电流10A - UL认可:UL1059 - VDE批准:DIN EN60998 - VDE额定电压:250V - VDE额定电流:24A
12420.1 价格&库存
很抱歉,暂时无法提供与“12420.1”相匹配的价格&库存,您可以联系我们找货
