Data sheet
12447.4 PK 114/15/7,50-V DG
PCB terminal, Wire protection, No. of poles: 15, Width: 113.2 mm, Colour: Dark grey
Business data
Article number
12447.4
Article name
PK 114/15/7,50-V DG
GTIN (EAN)
4044211032012
Packaging unit
50
Quantity unit
PC
Packaging type
Carton
Type of banding
Without
Weight per piece (not including packaging)
19.3 g
Weight per piece (including packaging)
20.3 g
Unit of weight
G
Customs number
85369010
Country of origin
QU
Prio-Article
12447.1
Creation date 16.12.2023 19:49:51
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
9 mm
Length of the pin
2.5 mm
Width
113.2 mm
Width left
4.45 mm
Width right
3.75 mm
Height
12.5 mm
Drill hole diameter
2 mm
Diameter of connecting pin
1 mm
Pitch
7.5 mm
Ratings
Rated voltage
500 V
Rated current
32 A
Rated cross-section
4 mm²
Rated impulse voltage
3 kV
Overvoltage category
III
Contamination degree
3
2
Data sheet
Technical data
Connection data
Connection principle
Wire protection
Connection type of PCB
Solder connection
Type of attachment to circuit board
Connecting contact
Angle of PCB/wire connection
0°/180° (horizontal)
No. of poles
15
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
2.5 mm²
Wire cross-section stranded with wire-end ferrules,min.
0.2 mm²
Wire cross-section stranded with wire-end ferrules,max.
2.5 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
12
Stripping length
7 mm
Screw threading
M3
Torque
0.5 Nm
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-30 °C
Working temperature, max.
105 °C
Clamping element
Brass
Screws
Steel
Wire protection
Stainless steel
3
Data sheet
Technical data
Further technical data
Storage temperature, min.
-40 °C
Storage temperature, max.
105 °C
Insulation resistance
1*10^13 Ohm x cm
Creepage-current resistance
CTI 600
Glow wire flammability index GWFI
GWFI 850
GWFI after-glow time
30 Sek.
Glow wire ignition temperature GWIT
GWIT 775 °C
GWIT exposure time
5 Sek.
Connection cycles, in compliance with standard
5
Recommended wave soldering temperature
265 °C
Recommended wave soldering duration, min.
3 Sek.
Recommended wave soldering duration, max.
4 Sek.
Environmental Product Compliance
REACH Conform
No
REACH Candidate Substance Note
No
REACH CAS 1 Percent minimal
0.1 %
REACH CAS 1 Percent maximum
4%
REACH CAS 1 Number
7439-92-1
RoHS Exception rule
6c
4
Data sheet
Approvals
cUL Recognized
cUL approval
CSA 22.2 No.158
cUL Usegroup B: rated voltage
300 V
cUL Usegroup B: rated current
20 A
cUL Usegroup C: rated voltage
150 V
cUL Usegroup C: rated current
10 A
cUL Usegroup D: rated voltage
300 V
cUL Usegroup D: rated current
20 A
cUL wire cross-section single-core (rigid) AWG, min.
22
cUL wire cross-section single-core (rigid) AWG, max. 12
cUL wire cross-section stranded AWG, min.
12
cUL wire cross-section stranded AWG, max.
22
cUL torque
0.8000000119 Nm
cUL wire material
Cu
cUL Recognized
1
UL Recognized
UL approval
UL 1059
300 V
20 A
150 V
10 A
300 V
20 A
22
12
12
22
UL torque
7398 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
5
Data sheet
Approvals
VDE approval
VDE approval
DIN EN 60998
VDE approval granted
yes
VDE rated voltage
500 V
VDE rated current
32 A
VDE rated current wire cross-section rigid, max.
32 A
VDE rated current wire cross-section stranded, max.
32 A
VDE rated impulse voltage
3 kV
VDE wire cross-section rigid, min.
0.5 mm²
VDE wire cross-section rigid, max.
4 mm²
VDE wire cross-section stranded, min.
0.5 mm²
VDE wire cross-section stranded, max.
4 mm²
VDE screw threading
M3
VDE torque
0.5 Nm
VDE overvoltage category
III
VDE contamination degree
3
6
Data sheet
Media
7
Data sheet
Accessories
8
很抱歉,暂时无法提供与“12447.4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+41.92560
- 200+16.23240
- 500+15.66000
- 1000+15.37920
