12463.1
12463.1
    CONTA-CLIP
    插件,P=7.5mm
    接线端子 1x19P 7.5mm 直插 排数:单排 每排Pin数:19
12463.1 数据手册
Data sheet 12463.1 PK 110/19/7,50-V GN PCB terminal, Wire protection, No. of poles: 19, Width: 143.2 mm, Colour: Green Business data Article number 12463.1 Article name PK 110/19/7,50-V GN GTIN (EAN) 4044211032340 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 23.3 g Weight per piece (including packaging) 24.9 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 12463.1 Creation date 16.12.2023 19:49:52 Subject to technical changes 1 Data sheet 12463.1 PK 110/19/7,50-V GN Technical data Dimensions Length 9 mm Length of the pin 4.5 mm Width 143.2 mm Width left 4.45 mm Width right 3.75 mm Height 12.5 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 7.5 mm Ratings Rated voltage 500 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 3 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 19:49:52 Subject to technical changes 2 Data sheet 12463.1 PK 110/19/7,50-V GN Technical data Connection data Connection principle Wire protection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) No. of poles 19 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 14 Stripping length 7 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Wire protection Stainless steel Creation date 16.12.2023 19:49:52 Subject to technical changes 3 Data sheet 12463.1 PK 110/19/7,50-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 260 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 19:49:52 Subject to technical changes 4 Data sheet 12463.1 PK 110/19/7,50-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 20 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 14 cUL wire cross-section stranded AWG, max. 22 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 20 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 14 UL wire cross-section stranded AWG, max. 22 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 19:49:52 Subject to technical changes 5 Data sheet 12463.1 PK 110/19/7,50-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 500 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 3 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:49:52 Subject to technical changes 6 Data sheet 12463.1 PK 110/19/7,50-V GN Media Creation date 16.12.2023 19:49:52 Subject to technical changes 7 Data sheet 12463.1 PK 110/19/7,50-V GN Accessories Creation date 16.12.2023 19:49:52 Subject to technical changes 8
12463.1
1. 物料型号:产品的型号是12463.1 PK 110/19/7,50-V GN。 2. 器件简介:该产品是一个PCB端子,用于线缆保护,具有19个极位,宽度为143.2毫米,颜色为绿色。 3. 引脚分配:每个引脚的长度是4.5毫米,引脚的间距(Pitch)为7.5毫米。 4. 参数特性: - 额定电压:500V - 额定电流:24A - 额定截面积:2.5 mm² - 额定脉冲电压:3kV 5. 功能详解:产品提供了线缆保护功能,通过焊接连接到PCB上,适用于单根或绞合线缆,最小截面积为0.2 mm²,最大截面积为2.5 mm²。 6. 应用信息:适用于需要线缆连接保护的场合,例如电气设备或电路板的接线。 7. 封装信息:产品包装单位为50个/箱,重量为每件23.3克(不包括包装),每件24.9克(包括包装)。
12463.1 价格&库存
很抱歉,暂时无法提供与“12463.1”相匹配的价格&库存,您可以联系我们找货
