12476.4
12476.4
    CONTA-CLIP
    插件,P=7.5mm
    PCB TERMINAL
12476.4 数据手册
Data sheet 12476.4 PK 110/20/7,50-H DG PCB terminal, Wire protection, No. of poles: 20, Width: 150.7 mm, Colour: Dark grey Business data Article number 12476.4 Article name PK 110/20/7,50-H DG GTIN (EAN) 4044211032623 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 24.2 g Weight per piece (including packaging) 25.8 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 12476.1 Creation date 16.12.2023 19:49:39 Subject to technical changes 1 Data sheet 12476.4 PK 110/20/7,50-H DG Technical data Dimensions Length 12.5 mm Length of the pin 3.8 mm Width 150.7 mm Width left 4.45 mm Width right 3.75 mm Height 9 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 7.5 mm Ratings Rated voltage 500 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 3 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 19:49:39 Subject to technical changes 2 Data sheet 12476.4 PK 110/20/7,50-H DG Technical data Connection data Connection principle Wire protection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 90° (vertically upwards) No. of poles 20 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 14 Stripping length 6 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Wire protection Stainless steel Creation date 16.12.2023 19:49:39 Subject to technical changes 3 Data sheet 12476.4 PK 110/20/7,50-H DG Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 260 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 19:49:39 Subject to technical changes 4 Data sheet 12476.4 PK 110/20/7,50-H DG Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 20 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 14 cUL wire cross-section stranded AWG, max. 22 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 20 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 14 UL wire cross-section stranded AWG, max. 22 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 19:49:39 Subject to technical changes 5 Data sheet 12476.4 PK 110/20/7,50-H DG Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 500 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 3 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 19:49:39 Subject to technical changes 6 Data sheet 12476.4 PK 110/20/7,50-H DG Media Creation date 16.12.2023 19:49:39 Subject to technical changes 7 Data sheet 12476.4 PK 110/20/7,50-H DG Accessories Creation date 16.12.2023 19:49:39 Subject to technical changes 8
12476.4
- 物料型号:12476.4 PK 110/20/7,50-H DG - 描述:PCB端子,用于线束保护,20个极位,宽度150.7毫米,颜色深灰色
技术数据包括: - 尺寸:长度12.5毫米,引脚长度3.8毫米,宽度150.7毫米,高度9毫米 - 额定电压:500V - 额定电流:24A - 额定截面积:2.5 mm² - 额定脉冲电压:3kV
连接数据: - 连接原理:线束保护 - PCB连接类型:焊接 - 连接角度:90°(垂直向上) - 极位数:20 - 电线截面积:最小0.2 mm²,最大2.5 mm² - 剥线长度:6mm - 螺丝螺纹:M3 - 扭矩:0.5Nm
材料信息: - 绝缘外壳材料:聚酰胺6.6 - 阻燃等级:UL 94 V-0 - 工作温度范围:-30°C至105°C - 压接元件材料:黄铜 - 螺丝材料:钢 - 线束保护材料:不锈钢
进一步的技术数据: - 存储温度范围:-40°C至105°C - 绝缘电阻:110^13欧姆x厘米 - 爬电电流电阻:CTI 600 - 灼热丝可燃性指数:GWFI850 - 连接周期:5次 - 推荐的波峰焊接温度:260°C
认证信息: - cUL认证:CSA 22.2No.158 - UL认证:UL1059 - VDE认证:DIN EN60998
12476.4 价格&库存
很抱歉,暂时无法提供与“12476.4”相匹配的价格&库存,您可以联系我们找货
