Data sheet
12610.4 PK 700/14/5,00-V DG
PCB terminal, Screw connection, No. of poles: 14, Width: 70.6 mm, Colour: Dark grey
Business data
Article number
12610.4
Article name
PK 700/14/5,00-V DG
GTIN (EAN)
4044211035402
Packaging unit
50
Quantity unit
PC
Packaging type
Carton
Type of banding
Without
Weight per piece (not including packaging)
26 g
Weight per piece (including packaging)
27.1 g
Unit of weight
G
Customs number
85369010
Country of origin
QU
Prio-Article
12610.1
Creation date 16.12.2023 19:59:51
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
10.5 mm
Length of the pin
4 mm
Width
70.6 mm
Width left
3.1 mm
Width right
2.5 mm
Height
19 mm
Drill hole diameter
1.3 mm
Diameter of connecting pin
0.9 mm
Pitch
5 mm
Ratings
Rated voltage
250 V
Rated current
24 A
Rated cross-section
2.5 mm²
Rated impulse voltage
2 kV
Overvoltage category
III
Contamination degree
3
2
Data sheet
Technical data
Connection data
Connection principle
Screw connection
Connection type of PCB
Solder connection
Type of attachment to circuit board
Connecting contact
Angle of PCB/wire connection
0°/180° (horizontal)
No. of poles
14
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
2.5 mm²
Wire cross-section stranded with wire-end ferrules,min.
0.25 mm²
Wire cross-section stranded with wire-end ferrules,max.
2.5 mm²
Wire cross-section AWG, min.
30
Wire cross-section AWG, max.
12
Stripping length
8 mm
Screw threading
M3
Torque
0.5 Nm
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-30 °C
Working temperature, max.
105 °C
Clamping element
Brass
Screws
Steel
Soldering lug
Copper alloy
3
Data sheet
Technical data
Further technical data
Storage temperature, min.
-40 °C
Storage temperature, max.
105 °C
Insulation resistance
1*10^13 Ohm x cm
Creepage-current resistance
CTI 600
Glow wire flammability index GWFI
GWFI 850
GWFI after-glow time
30 Sek.
Glow wire ignition temperature GWIT
GWIT 775 °C
GWIT exposure time
5 Sek.
Connection cycles, in compliance with standard
5
Recommended wave soldering temperature
265 °C
Recommended wave soldering duration, min.
3 Sek.
Recommended wave soldering duration, max.
4 Sek.
Environmental Product Compliance
REACH Conform
No
REACH Candidate Substance Note
No
REACH CAS 1 Percent minimal
0.1 %
REACH CAS 1 Percent maximum
4%
REACH CAS 1 Number
7439-92-1
RoHS Exception rule
6c
4
Data sheet
Approvals
cUL Recognized
cUL approval
C22.2 No 158
cUL Usegroup B: rated voltage
300 V
cUL Usegroup B: rated current
15 A
cUL Usegroup C: rated voltage
300 V
cUL Usegroup C: rated current
15 A
cUL Usegroup D: rated voltage
300 V
cUL Usegroup D: rated current
15 A
cUL wire cross-section single-core (rigid) AWG, min.
22
cUL wire cross-section single-core (rigid) AWG, max. 12
cUL wire cross-section stranded AWG, min.
22
cUL wire cross-section stranded AWG, max.
12
cUL torque
0.4499999881 Nm
cUL wire material
Cu
cUL Recognized
1
UL Recognized
UL approval
UL 1059
300 V
15 A
300 V
15 A
300 V
15 A
22
12
22
12
UL torque
4 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
5
Data sheet
Approvals
VDE approval
VDE approval
DIN EN 60998
VDE approval granted
yes
VDE rated voltage
250 V
VDE rated current
24 A
VDE rated current wire cross-section rigid, max.
24 A
VDE rated current wire cross-section stranded, max.
24 A
VDE rated impulse voltage
2 kV
VDE wire cross-section rigid, min.
0.5 mm²
VDE wire cross-section rigid, max.
4 mm²
VDE wire cross-section stranded, min.
0.5 mm²
VDE wire cross-section stranded, max.
2.5 mm²
VDE screw threading
M3
VDE torque
0.5 Nm
VDE overvoltage category
III
VDE contamination degree
3
6
Data sheet
Media
7
Data sheet
Accessories
8
很抱歉,暂时无法提供与“12610.4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+37.99440
- 200+14.70960
- 500+14.19120
- 1000+13.93200
