Data sheet
1262.2 IK 2,5 PNP/DC/LED(RD)/24V BG
Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated
cross-section: 2.5 mm², Width: 5 mm, Colour: Beige
Business data
Article number
1262.2
Article name
GTIN (EAN)
4044211035655
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
10.4 g
Weight per piece (including packaging)
11.25 g
Unit of weight
G
Customs number
85369010
Country of origin
BG
Product description
Colour
Beige
Creation date 16.12.2023 19:59:09
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
62.8 mm
Width
5 mm
Height TS 35/7.5
58.3 mm
Height TS 32
62.8 mm
Ratings
Rated voltage
250 V
Rated current
24 A
Rated cross-section
2.5 mm²
Rated impulse voltage
4 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
2.3 W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
4
Number of levels
3
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
2.5 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
14
Stripping length
7 mm
Screw head
Slotted
Screw threading
M 2,4
Tightening torque, min.
0.4 Nm
Tightening torque, max.
0.8 Nm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Gauge plug acc. to EN 60 947-1
A3
Number of cross-connection channels
3
End plate required
Can be cross-connected
Colour of lamp
Red
LED switching for
PNP
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
Approvals
cUL Recognized
cUL approval
C22.2 No 158
cUL Usegroup B: rated voltage
300 V
cUL Usegroup B: rated current
20 A
cUL Usegroup C: rated voltage
300 V
cUL Usegroup C: rated current
20 A
cUL wire cross-section single-core (rigid) AWG, min.
22
cUL wire cross-section single-core (rigid) AWG, max. 12
cUL wire cross-section stranded AWG, min.
22
cUL wire cross-section stranded AWG, max.
12
cUL torque
5.3 Nm
cUL wire material
Cu
cUL Recognized
1
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
250 V
KEMA rated current
24 A
KEMA rated impulse voltage
4 kV
KEMA wire cross-section single core (rigid), min.
0.2 mm²
KEMA wire cross-section single-core (rigid), max.
4 mm²
KEMA wire cross-section stranded, min.
0.2 mm²
KEMA wire cross-section stranded, max.
4 mm²
KEMA torque, min.
0.4 Nm
KEMA torque, max.
0.8 Nm
4
Data sheet
Approvals
UL Recognized
UL approval
UL 1059
300 V
20 A
300 V
20 A
22
12
22
12
UL torque
5.3 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
5
Data sheet
Media
6
Data sheet
Accessories
End plate
End plate, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2698.2
AP 2,5/I BG
4044211054373
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4600.7
PMC SB 5/50 WH
4044211088903
500 ST
Cross-connector
Cross-connector, No. of poles: 20, Mounting type: Can be screwed on, Width: 100.9 mm,
Rated cross-section: 2.5 mm², Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2700.0
Q 20
4044211054410
10 ST
Cross-connector, No. of poles: 98, Mounting type: Screwable, Width: 500 mm, Rated
Article number
Article name
GTIN (EAN)
Packaging
unit
2151.0
Q 0,5 m/98 Pole
4044211049720
1 ST
Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 49.9 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2425.0
Q 10
4044211052072
10 ST
7
Data sheet
Cross-connector
Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 9.1 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2422.0
Q2
4044211052041
50 ST
Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 14.2 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2423.0
Q3
4044211052058
50 ST
Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 19.3 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2424.0
Q4
4044211052065
20 ST
Cross-connection rail
Cross-connection rail, No. of poles: 10, Mounting type: Can be screwed on, Width: 49.9
mm, Rated cross-section: 2.5 mm², Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2420.0
QS 10
4044211052027
10 ST
Cross-connection rail, No. of poles: 98, Mounting type: Can be screwed on, Width: 500
Article number
Article name
GTIN (EAN)
Packaging
unit
2519.0
QS 0,5 m
4044211053215
1 ST
8
Data sheet
Cross-connection rail, No. of poles: 4, Mounting type: Can be screwed on, Width: 19.3
Article number
Article name
GTIN (EAN)
Packaging
unit
2419.0
QS 4
4044211052010
50 ST
Cross-connection rail, No. of poles: 3, Mounting type: Can be screwed on, Width: 14.2
Article number
Article name
GTIN (EAN)
Packaging
unit
2418.0
QS 3
4044211052003
100 ST
Cross-connection rail, No. of poles: 2, Mounting type: Can be screwed on, Width: 9.1
Article number
Article name
GTIN (EAN)
Packaging
unit
2417.0
QS 2
4044211051990
100 ST
Screwdriver
Screwdriver with bare blade, Colour: Black-grey
Article number
Article name
GTIN (EAN)
Packaging
unit
1085.0
SDB 0,5x3,0
4044211014643
1 ST
Connecting sleeve
Connecting sleeve, Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2327.0
VH 5
4044211051129
100 ST
9
