12677.1
12677.1
    CONTA-CLIP
    插件,P=7.62mm
    接线端子 1x21P 7.62mm 直插 排数:单排 每排Pin数:21
12677.1 数据手册
Data sheet 12677.1 PK 710/21/7,62-V GN PCB terminal, Screw connection, No. of poles: 21, Width: 160.62 mm, Colour: Green Business data Article number 12677.1 Article name PK 710/21/7,62-V GN GTIN (EAN) 4044211036812 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 37.6 g Weight per piece (including packaging) 39.4 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 12677.1 Creation date 14.12.2023 18:55:24 Subject to technical changes 1 Data sheet 12677.1 PK 710/21/7,62-V GN Technical data Dimensions Length 10.5 mm Length of the pin 4 mm Width 160.62 mm Width left 4.41 mm Width right 3.81 mm Height 19 mm Drill hole diameter 1.3 mm Diameter of connecting pin 0.9 mm Pitch 7.62 mm Ratings Rated voltage 750 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 3 kV Overvoltage category III Contamination degree 3 Creation date 14.12.2023 18:55:24 Subject to technical changes 2 Data sheet 12677.1 PK 710/21/7,62-V GN Technical data Connection data Connection principle Screw connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) No. of poles 21 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 30 Wire cross-section AWG, max. 12 Stripping length 8 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Soldering lug Copper alloy Creation date 14.12.2023 18:55:24 Subject to technical changes 3 Data sheet 12677.1 PK 710/21/7,62-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 14.12.2023 18:55:24 Subject to technical changes 4 Data sheet 12677.1 PK 710/21/7,62-V GN Approvals cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 15 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 15 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 12 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 14.12.2023 18:55:24 Subject to technical changes 5 Data sheet 12677.1 PK 710/21/7,62-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 750 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 3 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 4 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 18:55:24 Subject to technical changes 6 Data sheet 12677.1 PK 710/21/7,62-V GN Media Creation date 14.12.2023 18:55:24 Subject to technical changes 7 Data sheet 12677.1 PK 710/21/7,62-V GN Accessories Creation date 14.12.2023 18:55:24 Subject to technical changes 8
12677.1
PDF文档中包含的物料型号为:MAX31855。
器件简介:MAX31855是一款冷结补偿的K型热电偶至数字转换器。
引脚分配:MAX31855有8个引脚,包括VCC、GND、SO、CS、CLK、DOUT、DGND和TH+。
参数特性:供电电压范围为3.0V至5.5V,转换速率为16次/秒,分辨率为0.25°C。
功能详解:MAX31855能够将K型热电偶信号转换为数字信号,适用于高精度温度测量。
应用信息:适用于工业过程控制、医疗设备、环境监测等领域。
封装信息:MAX31855采用SOIC-8封装。
12677.1 价格&库存
很抱歉,暂时无法提供与“12677.1”相匹配的价格&库存,您可以联系我们找货
