12689.4
12689.4
    CONTA-CLIP
    插件,P=5mm
    接线端子 2x21P 5mm 直插 排数:双排 每排Pin数:21
12689.4 数据手册
Data sheet 12689.4 PKD 750/21/5,00-V DG Double-level PCB terminal, Screw connection, No. of poles: 21, Width: 108.1 mm, Colour: Dark grey Business data Article number 12689.4 Article name PKD 750/21/5,00-V DG GTIN (EAN) 4044211037062 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 102.19 g Weight per piece (including packaging) 104.79 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 12689.1 Creation date 16.12.2023 20:00:33 Subject to technical changes 1 Data sheet 12689.4 PKD 750/21/5,00-V DG Technical data Dimensions Length 21.5 mm Length of the pin 4 mm Width 108.1 mm Width left 3.1 mm Width right 5 mm Height 34 mm Drill hole diameter 1.3 mm Diameter of connecting pin 0.9 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 20:00:33 Subject to technical changes 2 Data sheet 12689.4 PKD 750/21/5,00-V DG Technical data Connection data Connection principle Screw connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) Number of electrical connections 42 No. of poles 21 Number of levels 2 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 30 Wire cross-section AWG, max. 12 Stripping length 8 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Soldering lug Copper alloy Creation date 16.12.2023 20:00:33 Subject to technical changes 3 Data sheet 12689.4 PKD 750/21/5,00-V DG Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 20:00:33 Subject to technical changes 4 Data sheet 12689.4 PKD 750/21/5,00-V DG Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 30 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 30 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 30 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 30 UL wire cross-section stranded AWG, max. 12 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:00:33 Subject to technical changes 5 Data sheet 12689.4 PKD 750/21/5,00-V DG Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 4 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 20:00:33 Subject to technical changes 6 Data sheet 12689.4 PKD 750/21/5,00-V DG Media Creation date 16.12.2023 20:00:33 Subject to technical changes 7 Data sheet 12689.4 PKD 750/21/5,00-V DG Accessories Creation date 16.12.2023 20:00:33 Subject to technical changes 8
12689.4
物料型号:12689.4 PKD 750/21/5,00-V DG
器件简介:这是一个双排PCB端子,采用螺钉连接方式,共有21个极,宽度为108.1毫米,颜色为深灰色。
引脚分配:共有42个电气连接点,分为两层,每层21个极。
参数特性:额定电压250V,额定电流24A,额定截面积2.5 mm²,额定脉冲电压2kV,污染等级3。
功能详解:端子的连接原理是螺钉连接,PCB的连接类型是焊接连接。端子与电线连接的角度为0°/180°(水平)。端子适用于不同截面积的单芯或绞合电线。
应用信息:适用于需要电气连接的PCB应用,如电源、信号传输等。
封装信息:绝缘体材料为聚酰胺6.6,阻燃等级为UL 94 V-0,工作温度范围从-30°C至105°C,夹持元件材料为黄铜,螺丝为钢制,焊盘为铜合金。
12689.4 价格&库存
很抱歉,暂时无法提供与“12689.4”相匹配的价格&库存,您可以联系我们找货
