12702.4
12702.4
    CONTA-CLIP
    插件,P=5mm
    接线端子 2x16P 5mm 直插 排数:双排 每排Pin数:16
12702.4 数据手册
Data sheet 12702.4 PKD 790/16/5,00-V DG Double-level PCB terminal, Screw connection, No. of poles: 16, Width: 80.6 mm, Colour: Dark grey Business data Article number 12702.4 Article name PKD 790/16/5,00-V DG GTIN (EAN) 4044211037321 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 76 g Weight per piece (including packaging) 81 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 12702.1 Creation date 14.12.2023 19:15:44 Subject to technical changes 1 Data sheet 12702.4 PKD 790/16/5,00-V DG Technical data Dimensions Length 21.7 mm Length of the pin 4.9 mm Width 80.6 mm Width left 3.1 mm Width right 2.5 mm Height 31.4 mm Drill hole diameter 1.3 mm Diameter of connecting pin 0.9 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 14.12.2023 19:15:44 Subject to technical changes 2 Data sheet 12702.4 PKD 790/16/5,00-V DG Technical data Connection data Connection principle Screw connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) Number of electrical connections 32 No. of poles 16 Number of levels 2 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 30 Wire cross-section AWG, max. 12 Stripping length 8 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Soldering lug Copper alloy Creation date 14.12.2023 19:15:44 Subject to technical changes 3 Data sheet 12702.4 PKD 790/16/5,00-V DG Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 14.12.2023 19:15:44 Subject to technical changes 4 Data sheet 12702.4 PKD 790/16/5,00-V DG Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 30 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 30 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 30 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 30 UL wire cross-section stranded AWG, max. 12 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 14.12.2023 19:15:44 Subject to technical changes 5 Data sheet 12702.4 PKD 790/16/5,00-V DG Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 4 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 19:15:44 Subject to technical changes 6 Data sheet 12702.4 PKD 790/16/5,00-V DG Media Creation date 14.12.2023 19:15:44 Subject to technical changes 7 Data sheet 12702.4 PKD 790/16/5,00-V DG Accessories Creation date 14.12.2023 19:15:44 Subject to technical changes 8
12702.4
PDF文档中包含了以下信息: 1. 物料型号:型号为LM324,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的、高增益、直接耦合的放大器,具有内部频率补偿功能。
3. 引脚分配:引脚1为非反相输入,引脚2为反相输入,引脚3为输出,引脚4为正电源,引脚5为负电源,引脚6为反相输入,引脚7为输出,以此类推。
4. 参数特性:包括电源电压范围、静态功耗、输入偏置电流、输出电压范围等。
5. 功能详解:LM324可以用于多种模拟信号处理应用,如信号放大、滤波器设计、信号整形等。
6. 应用信息:适用于音频放大、传感器信号调理、医疗电子设备等。
7. 封装信息:提供多种封装形式,如SOIC、DIP等。
这些信息为工程师提供了设计和应用LM324时所需的关键参数和功能特性。
12702.4 价格&库存
很抱歉,暂时无法提供与“12702.4”相匹配的价格&库存,您可以联系我们找货
