12749.1
12749.1
    CONTA-CLIP
    插件,P=5.08mm
    接线端子 间距:5.08mm 直插
12749.1 数据手册
Data sheet 12749.1 STL 970/24/5,08-V GN Male pin block, No. of poles: 24, Width: 124.46 mm, Colour: Green Business data Article number 12749.1 Article name STL 970/24/5,08-V GN GTIN (EAN) 4044211037703 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 26.8 g Weight per piece (including packaging) 29.8 g Unit of weight G Customs number 85366930 Country of origin QU Colour Green Creation date 15.12.2023 02:18:13 Subject to technical changes 1 Data sheet 12749.1 STL 970/24/5,08-V GN Technical data Dimensions Length 22 mm Length of the pin 3.5 mm Width 124.46 mm Width left 2.54 mm Width right 5.08 mm Height 23.5 mm Drill hole diameter 1.4 mm Diameter of connecting pin 1 mm Pitch 5.08 mm Ratings Rated voltage 250 V Rated current 12 A Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 0°/180° (horizontal) Number of plug-in rows 2 No. of poles 24 Materials Insulation housing Polybutylene terephthalate Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Copper alloy Creation date 15.12.2023 02:18:13 Subject to technical changes 2 Data sheet 12749.1 STL 970/24/5,08-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 175 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 02:18:13 Subject to technical changes 3 Data sheet 12749.1 STL 970/24/5,08-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 12 A VDE rated impulse voltage 4 kV VDE overvoltage category III VDE contamination degree 3 Creation date 15.12.2023 02:18:13 Subject to technical changes 4 Data sheet 12749.1 STL 970/24/5,08-V GN Media Creation date 15.12.2023 02:18:13 Subject to technical changes 5 Data sheet 12749.1 STL 970/24/5,08-V GN Accessories Creation date 15.12.2023 02:18:13 Subject to technical changes 6
12749.1 价格&库存
很抱歉,暂时无法提供与“12749.1”相匹配的价格&库存,您可以联系我们找货
